Rear axle oil leak - Help!
2newbies
Post by 2newbies » Tue Jun 18, 2013 7:34 pm
I was peering underneath Daisy and noticed what looks like an oil leak coming from the middle nut on the bulbous bit on the middle of the rear axle (could that be the diff...?)
Will it be a case of simply tightening the nut up to stop it, or is it a bit more technical than that...?
Many thanks as ever.
Paul & Claire
wonkanoby
Re: Rear axle oil leak - Help!
Post by wonkanoby » Tue Jun 18, 2013 7:35 pm
nip it up
if you have the oil might be time to change it
briwy
Post by briwy » Tue Jun 18, 2013 8:05 pm
Check the breather on top isn't bunged up. If it is pressure can build up and blow the oil out through the seals.
2newbies
Post by 2newbies » Tue Jun 18, 2013 8:52 pm
Thanks both. Re: the breather - do you recommend any particular way to clean it out if that's the problem? (sorry to be so dense...!)
Paul & Claire
Post by Northern Bongolow » Tue Jun 18, 2013 11:42 pm
grab the breather, then twist it, backwards and forwards both directions, then try and lift as you turn, this will free it off a tad.
rita
Post by rita » Wed Jun 19, 2013 11:39 am
The breather unit is best removed,cleaned,tested and refitted if ok.
breather (0730-26-060) - Rosenthal Arlington Mazda Parts Store
PS,the breather cap is normally pinned.
