front bullbar fitting
Moderator: Ian
junior
Post by junior » Mon Apr 29, 2013 1:30 pm
hi friends, just purchased a front bull bar with spots, sump plate etc and im reassured that it will have all the bolts and fixings when it arrives. but i could do with some advice on wether its hard to fit or any tips on how to fit it please. bit of a semi novice diy er but prepared to have a go. thanks.
Re: front bullbar fitting
Post by mikeonb4c » Mon Apr 29, 2013 2:59 pm
Bar and guard very easy to fit, make sure you get the bottom brackets included. Spots will obviously need you to understand how to wire them up.
junior
Post by junior » Tue Apr 30, 2013 2:38 pm
mikeonb4c wrote:Bar and guard very easy to fit, make sure you get the bottom brackets included. Spots will obviously need you to understand how to wire them up.
thanks for that. All seems pretty straight forward then
Post by mikeonb4c » Tue Apr 30, 2013 3:32 pm
Yes its easy to see what bolts go in where when you offer the parts up to the body (oooh matron) as long as yer nuts are obliging and not rusted on :shock:
Return to “Pimp My Bongo”
