Festoon light
lancyman
Festoon light
Post by lancyman » Fri Apr 19, 2013 9:37 am
Hi All,
My festoon light by the back door isn't working.
I removed it last night and it wasn't wired in,
Or the connection had broken. How do I wire it up?
I looked behind the light and couldn't see any wires
Hanging off.
Thanks.
Re: Festoon light
Post by g8dhe » Fri Apr 19, 2013 3:20 pm
Pretty sure its fitted on all versions/years so the wiring loom should be present, maybe someone got there before you ?
Its the 10W I3-01 fitting on the left below;
lancyman
Re: Festoon light
Post by lancyman » Sat Apr 20, 2013 7:49 am
Had another look last night. The lights had been
Tinkered with. I have a second tube light above the door.
Looks like the wiring was used to power this. I played
About for a bit and tried to install the festoon again,
Plus add an led strip. Unfortunately in my rumblings I
Blew the interior lights, and central locking. Will this just
Be a replace the fuse job?
dave_aber
Re: Festoon light
Post by dave_aber » Sat Apr 20, 2013 7:54 am
Check the top left fuse on the fusebox by the driver's knee.
Image...Image
lancyman
Re: Festoon light
Post by lancyman » Sat Apr 20, 2013 11:00 am
All sorted now. It was the fuse. Phew!
