Front brake calliper slider pins/bolts
tigger
Post by tigger » Wed Mar 06, 2013 10:59 am
Morning
Slightly dumb-ass question, just need to double check...
N/S Front brake calliper, '95 Bongo (non-ABS). There are two slider pins that the floating calliper 'floats' on. One of the pins is longer and fatter than the other one.
Which pin goes at the top of the calliper assembly and which pin goes at the bottom????
I know I'm being dumb...
Dom
Re: Front brake calliper slider pins/bolts
Post by g8dhe » Wed Mar 06, 2013 11:45 am
tigger
Post by tigger » Wed Mar 06, 2013 11:56 am
Thanks. It's a useful diagram, but I'm not sure that in this instance it helps much (unless I'm missing something). The bolts in the image both look the same. I tried googling the part codes it lists for the bolts, but without much success...
teenmal
Post by teenmal » Wed Mar 06, 2013 12:49 pm
Hi,check the hole sizes on the carrier or check the O/S caliper for a reference.
tigger
Post by tigger » Wed Mar 06, 2013 12:58 pm
Hole sizes slightly inconclusive believe it or not.
Yes I could dismantle the other one but I'm hoping someone on here just knows the answer as it saves me some extra faffing about.
Anyone? I bet Doone knows...
Simon Jones
Post by Simon Jones » Wed Mar 06, 2013 2:04 pm
If one pin is fatter than the other, surely one hole is larger than the other?
tigger
Post by tigger » Wed Mar 06, 2013 2:53 pm
Both of the receiving holes in the calliper hanger are about the same size. The upper one contains a rubber sleeve running all the way through it, the lower one is bare metal.
Obviously the rubber sleeve reduces the internal diameter of the hole it sits in, so logically this is where the thinner bolt goes. But because rubber is flexible it will receive either, albeit the thicker one being a tight fit.
As I say I'm just hoping that someone who actually knows this off the top of their head can confirm or otherwise for me...
hijimhere
Post by hijimhere » Wed Mar 06, 2013 5:53 pm
larger on bottom - just fittled nsf calliper to 96 2.5td
tigger
Post by tigger » Wed Mar 06, 2013 6:02 pm
Cheers buddy very helpful.
And just what I was hoping you'd say! :D
