Hi guys, just bought a anew fuel filter off ebay for my 2.5 td freeda and had a look under drivers door to see where she fits an bingo there it is.
Anyway justnoticed that the hydraulic lever that goes into the 'gearbox'??? that is on the o/s ofthe engine appearsto be leeking, should I be worried, is it an easy fix.
Hi its a. Manual Ford Freeda and is located about half way up what I think is the gear box which is connected to a flexible hose that runs the o/s to a connection, ill have another look tonight when I get home from work.
Motor factors will sell slave cylinder repair kits .you get seals,spring? If fitted and dust cover.(new poss twenty quid)but that's a guess
Hope this helps
