Coolant pressure sensor
chipvan
Re: Coolant pressure sensor
Post by chipvan » Tue Feb 12, 2013 12:32 am
The Great Pretender wrote:
Driver+Passengers wrote:
The Great Pretender wrote:Feeding the overflow pipe into a further bottle or tank that was open to atmosphere with the pipe covered with coolant would be better than the standard system. :wink:
Can you explain why? I can't see it yet...
Justs gives more room for expansion.
With the system in good health it is belts n braces, but if there is a problem instead of dumping the coolant onto the floor it draws it back in when the system cools.
this is interesting..are many doing this mod?
The Great Pretender
Post by The Great Pretender » Fri Feb 15, 2013 1:42 am
That looks like a no then...................You gonna be the first? :wink:
To infinity and beyond
