HELP PLZ
HELP PLZ
hi iv got a bongo 2.5 td and under the bonnet there is a fuse box and on the cover to the fuse box it says main on it but the relay is missing should it be missing
Re: HELP PLZ
Do you mean relay or fuse? The position of the main fuse varies, depending on the year of the van - see http://www.igmaynard.co.uk/bongo/member ... usebox.pdf
Re: HELP PLZ
Probably, it could be for optional extras, leccy blinds heated mirrors etc, does everything in your van work as it should
Re: HELP PLZ
my van is a 1996 and it got all the extras i think its a relay as it got 4 fins
- westonwarrior
Re: HELP PLZ
Are you having any problems ?
Does some thing not work as it wont start without the main fuse, if I remember correctly
Re: HELP PLZ
it smokes on start up and the hold light is flashing and speedo isnt working
- westonwarrior
Re: HELP PLZ
Check the connection on the back of the speedo one may be loose, if you have a chip try with out that, that may be the cause of the flashing and speedo not working,
the smoke depends on the colour .
Re: HELP PLZ
i think its blue
Re: HELP PLZ
The relay marked MAIN is used on the petrol vehicles it switches the main power on/off to the fuel pump and its relay, and too the Injectors and a few other things under control of the ECU.
Re: HELP PLZ
Flashing hold light indicates fault with the gearbox: http://www.igmaynard.co.uk/bongo/member ... dlight.pdf
If the speedo is not working I would hazard a guess that the speed sensor has failed which is a fairly common problem, although its worth eliminating a fault with the speedo chip (if fitted)
Re: HELP PLZ
Just to add,
When the guys above mention a "chip" or "speedo chip" this is a simple after-market conversion on the back of the speed dial to convert the readings from kilometres used in the rest of the world (ish.) to miles in the UK.
This modification can cause issue if it comes lose/disconnected or faulty itself....
If your odometer racks up kilometres though, the chances are just the speed dial faceplate was changed to read the speed in miles.... In which case i would be looking for a fault elsewhere?
Though i wouldn't rule out one of the connectors at the top back of the dial cluster not quite making contact/clipped in with the "flexible" PCB though..?!!
Hope this helps..?!
Hope this helps..?!
