Hi All
I own a Bongo 2.5TD P registration.
The ABS light came on some weeks ago. The garage I took it to has checked the sensors and brake lights and they think its the ABS pump that's faulty. The mechanic said that its probably the electronics in the pump that's gone and he will try to source a second hand pump or get it reconditioned. He added that he found a diagnostic port under the dashboard but would probably have to take it to a Mazda centre to use it if any more investigation is needed.
I just wondered if any of you out there had any advice on this matter and also if you knew where I could source an ABS pump.
Many thanks
Steve
ABS Pump
Re: ABS Pump
Hi,if its seconhand you are looking for,try here.
http://www.ebay.co.uk/itm/Mazda-Bongo-a ... HOP:GB:101
Re: ABS Pump
Thanks for your advice.
The prices seem reasonable.
Any idea of the seller's reliability?
Steve
Steve
Re: ABS Pump
yes he is a very good seller, i will vouch for him, ive used him a lot and have seen his breaking operation.
his name is george.
his name is george.
Re: ABS Pump
George was very communicative and helpful until he put his price up from £30 to £80!
I guess that's what you'd call capitalism in action.
Re: ABS Pump
Signof4 wrote:Hi
Hi,I am sorry that I pointed you in his direction..Wont happen again.
Did you get another unit?
Re: ABS Pump
One here for £40:
http://www.ebay.co.uk/itm/Mazda-Bongo-2 ... 27cfdffeaa
Alternatively, try Kevin at Southern Bongos who I've always found to be reasonably priced.
Re: ABS Pump
Thanks Simon
Will follow up
Will follow up
