only starts with spray....dummies guide please :)
hi,
Having problems starting bongo when cold...... It will only start with 'easy start' spray.
I have checked the glow plug rail and there doesn't appear to be any voltage. I have tried this with ignition on and off.
I don't have a 'cold start' switch in cab.
I am not sure how to check if 'glow plug relay' is working.
I will check the glow plug fuse 2moro.
Is it necessary to disconnect battery at any particular stage?
When I start it with spray there is white smoke for a few seconds.
It's an N reg diesel 2.5 automatic.
Well .....any advice would be greatly appreciated and as is probably obvious...I am a complete novice.
thanks
thanks
Jim the Box
- Tribal Elder
Re: only starts with spray....dummies guide please :)
Don't use the spray too often it's not good for the engine. I have a petrol V6 but posts will follow from others re the glow plugs etc.
"Today's rain is tomorrow's Whisky"
Stop right away using easy start ether you may knacker your bongo this stuff shouldn't be sold get the veh checked it could save you the price of a engine
- haydn callow
You must get power to the glow rail.........the fuse is just a thick wire that you will find connected to the pos battery terminal
The relay is on the inside wheel arch behind and to the side if the starter battery.
I think there is another normal fuse in the fuse box.
Odds are one of these 3 components are the problem
hi,
thanks for replies.
does anyone know how to check the glow plug relay ?
and ....maybe a silly question but do I need to disconnect battery before i remove relay for testing?
thanks
thanks for replies.
thanks
You should hear it clicking, if it's working.
Put a test light onto the glow plug bar turn on the ign and se if it illuminates .if it does it should only b for a few seconds.if it don't light further check reqd
just wondering if anyone has a pic of drivers fuse box? mine is in japanese and not sure which is associated with glow plug relay
thanks
thanks
There are several fuses associated with the glowplugs but have just responded to your PM so more details there.
hi,
I have started a new thread under 'glow plug relay problems'
thanks
thanks
