To the right of a black plastic box, is a stout lever about 3/16" thick and less than 6" long this has a threaded portion and has a special nylon nut screrwed on which has broken away (I can see an area of jagged nylon) from it's connecting part which is above and just out of sight and would be behind the exterior plastic handle.
Does anyone know if there are any spares availablle for the door mech - it looks like I could unscrew the nylon nut, replace it and then recconect it to the upper part.
Thanks in aticipation
Pete
