LED AFT roof light
Moderator: Ian
LED AFT roof light
Hi folks.
Following on from http://www.igmaynard.co.uk/bongo/forum/ ... 44&t=39610
I'd like to know if anyone can help with a choice of a 48-LED WHITE roof light for the interior of the AFT?
The current choices on FleaBay are viewable at
http://www.ebay.co.uk/sch/i.html?_nkw=4 ... &_from=R40
Does anyone know what size of LED panel will fit?
Many thanks.
Many thanks.
Re: LED AFT roof light
There are at least two types of Fluorescent tube light used in the bongo, your better off opening it up and measuring what will fit inside, bearing in mind that you will have to do away with the inverter that powers the existing light, and reconnect it direct to the 12 volts.
Geoff: the light I mean is the dome light in the AFT roof, behind the skylight -- not the fluorescent tube.
Ah right, yes you did say AFT, had my eyes half on the snow as it drifts down here!
I found the 48 LED panels were a too bright when sleeping in the AFT as they were quite near my head so I put these in
http://www.ebay.co.uk/itm/T10-FESTOON-T ... 1e687c86d1
though they might have been smaller than 39mm - you will need to measure your existing.
They still give a lot of light but you won't need
I replaced all the interior lights with the LED equivalent and it is plenty bright enough inside for me.
Thanks for your replies, folks.
Now, does anyone have any advice/caveats for removing the plastic cover for that light?
Cheers!
Cheers!
Please may i slightly hijack this slightly in order to stop an 'almost' duplicate thread.
Ive been looking at this as well - the older locked thread has dead links so just want to make sure looking at correct lights
For cab lights? (x2):
http://www.ebay.co.uk/itm/36-LED-Xenon- ... 53f3794d74
For rear light (on side by tailgate)?
http://www.ebay.co.uk/itm/24-LED-CAR-IN ... 41700aeb99
For AFT Light?
http://www.ebay.co.uk/itm/48-LED-WHITE- ... 41700aec7e
Pain them not being buy it now auctions - ordering multiples not possible either
The main fluorescent will need some chopping i bleieve to fit LED's?
Tim
For AFT Light?
Tim
For information I have just bid on the tailgate one and set a maximum bid of 7.51, I don't know what they normally go for but it is at £3.21 and with me.
It's at £6.52 now with 22 hours to go.
Cheers I probably won't win it then as it usually all happens in the least few minutes.Simon Jones wrote:It's at £6.52 now with 22 hours to go.
, just didn't want anyone bidding against me that was going to drop out at less than my Max Bid
Might be worth asking seller if they have a Buy It Now price for the next one.
I have led cab lights. When they start to fail, they flicker. Also, their light is bluish and cold. Personally, and for the amount of time the AFT light spends on, I prefer the warm and good light the standard bulb gives.
Oh God, I didn't bother measuring mine and they are 10mm shorter. And I ordered double by mistake. should be easy and fun to make an adaptor! Got 3 spare , 3 squid posted each, or 2.50 collected delivered 3miles R BS4. Incidentally, are they polarity dependant?Rebiam wrote:I found the 48 LED panels were a too bright when sleeping in the AFT as they were quite near my head so I put these in
They still give a lot of light but you won't need![]()
I won this one, just waiting for delivery. Thanks everyone for not bidding against meVelocette wrote:Cheers I probably won't win it then as it usually all happens in the least few minutes.Simon Jones wrote:It's at £6.52 now with 22 hours to go.
, just didn't want anyone bidding against me that was going to drop out at less than my Max BidI guess they relist them over and over?
