Service failed Windscreen Washer Motor with Pics DONT DELETE
wonkanoby
Re: Service failed Windscreen Washer Motor with Pics DONT DE
Post by wonkanoby » Wed Jun 13, 2012 1:13 pm
thanks
fixed my front washers for nowt love it
paulmorgan
Post by paulmorgan » Sun Dec 02, 2012 12:57 pm
Great tip - just fixed my rear pump.
alistair rose
Post by alistair rose » Tue Dec 04, 2012 4:28 pm
Hello,is there a fuse for washers?My mate & i have just bought Bongos.He has washer problems & was told by seller it's just the fuse.More likely same as your's.Cheers Ali bongo.
Bongo - go - go.
Post by g8dhe » Tue Dec 04, 2012 5:10 pm
Yes there are a pair of fuses;
Front Washers and Wipers Image
Rear washers and wipers Image
Post by Northern Bongolow » Tue Dec 04, 2012 9:48 pm
alistair rose wrote:Hello,is there a fuse for washers?My mate & i have just bought Bongos.He has washer problems & was told by seller it's just the fuse.More likely same as your's.Cheers Ali bongo.
if the wipers are working i dont think its a fuse. more likely the lecky connections or the motor in the pump has seized or if you can hear the separate motors humming but there is no water then the water supply may be it, there is a one way valve at the rear end that can become blocked to the rear wash nozzle.
Dodgey
Post by Dodgey » Fri Nov 29, 2013 2:29 pm
A thankyou from me. I fixed it no problems.
I've ordered a £5.64 one off ebay just to keep a spare!
hijimhere
Post by hijimhere » Fri Nov 29, 2013 9:44 pm
Just checked both pumps on a bottle I got from breaker...... the brushes look new no corrosion -- terminals cleaned up --- and all assembled ready for fitting -- my bottle has been leaking -- must be from one or both pump to bottle seal/grommet. Will fill this one & test for leaks first.
Mark Elvin
Post by Mark Elvin » Tue Jun 03, 2014 3:29 pm
I found soaking in coke removed all the corrosion.
Eat Aunt
Location: Bongoing since 2005 in the Portsmouth area :)
Post by Eat Aunt » Fri Jan 02, 2015 5:31 pm
Very helpful thread =D>
Thanks all, would not have dismantled both pumps without the pictures and advice \:D/
20 YEARS BONGO-ING
Black Std 2WD AFT
Now 2001 WHITE V6 Tintop ... 253,000 Km
Spencer54
Post by Spencer54 » Sat Jan 03, 2015 2:23 am
Subaru ones are an exact match for the front if you need a new one
http://www.ebay.co.uk/itm/ACP-Front-Sin ... 5b095b39ec
philpdr
Post by philpdr » Sat Jan 03, 2015 12:15 pm
Spencer54 wrote:Subaru ones are an exact match for the front if you need a new one
Good find!
Eat Aunt
Post by Eat Aunt » Sat Jan 03, 2015 12:47 pm
Nice one Spencer54 I'll get one of those. Thanks
As an additional bit of info: If the wipers work but no working washer, either front or rear, it is definitely not the fuse (after checking for blockages)
Cheers , Ian
20 YEARS BONGO-ING
Black Std 2WD AFT
Dungoisdadsbongo
Re: Service failed Windscreen Washer Motor with Pics DONT DELETE
Post by Dungoisdadsbongo » Sat Jan 27, 2018 9:19 am
Good morning Bongo lovers!
I was wondering if it would be possible to have the photos reposted as the photo bucket third party access has blocked the original ones. I really need to get the pumps looked at and the above thread seems to have helped with this.
Here's hoping :D
Post by g8dhe » Sat Jan 27, 2018 11:23 am
Northern Bunglows post reposted with pictures:-
Tools Needed:full toolkit, socket set including 10-20mm sockets, screwdriver set, service spray (wd40 or similar). lots of patience #-o
Symptoms:
No water on front or rear srcreen, no motor activation/noise of pump/s behind front nearside headlight.if you have pump noise but no water check the nozzles, pipework, and the inline one way valves, the rear one way valve is located in the rear roof space, if you locate the waterpipe at the rear door opening and gently pull the gromet out on the body side, about 6 inches down is a oneway valve that gets full of gunge, remove and blow clear.
how to:
if you have 2 batteries remove the nearside one with the usual care of short circuit. remove the batt tray.remove the front grill, remove the nearside headlight/sidelight. remove the 2 10mm bolts thet hold the top edge of the washer res to the slam panel, lift the res upwards, the res is now free but still connected to the pipework at the lower edge,and the lecky bits.
you may have to move wiring harnesses to lift enough to work on the pumps.
remove the pump/s:
they are just push fit into the res so gently lever away from the body,they are held watertight with a rubber gromet. free the lecky plug/s.
the plugs are different but may be swapable if you follow the guide below and remove the lecky connection part and swap over,but this needs to be confirmed as ive only stripped the rear wash pump.
piscs 1 and 2 show the removed rear wash pump. if you gently pull on the lecky conection block it will pop out, its held in by a rubber ring, and the springs that rub on the com, just pull evenly.
pics 3-4 show the inner bits/com,this will prob be full of crud and mine was siezed solid. wash out with penetrating spray or similar. i had to gently rotate the shaft/com using a very small screwdriver by levering against the com and the side body, once some movement was obtained more spray to wash out the crud, repeat until its really smooth to rotate, final wash out then move to the lecky contacts on the plug bit, just a light degunge with some light emery cloth and a wash off then gently push back together making sure the brushes go one either side of the com, lubricate the sealing ring and snap back together, job done.
back together: note the dirrection the plug should face.
dont be tempted to remove the white plastic base,it looks like it may come off but it may be destroyed in the proccess. #-o
to rebuild the motor to the bottle push the ruber gromet into the res first, then gently but firmly push the motor through the gromet until it snaps into place,(lub first).
test the motor before you remount the res and rebuild the front of your bongo.
should take a couple of hours start to finish.
good luck.
coffee and bacon sandwiches provided by northern bongolow :D :D :wink:
Post by Bob » Sat Jan 27, 2018 11:40 am
Well done Geoff and Ady. =D>
