Service failed Windscreen Washer Motor with Pics DONT DELETE
Post by Northern Bongolow » Sun Jan 15, 2012 6:43 pm
Tools Needed:full toolkit, socket set including 10-20mm sockets, screwdriver set, service spray (wd40 or similar). lots of patience #-o
Symptoms:
No water on front or rear srcreen, no motor activation/noise of pump/s behind front nearside headlight.if you have pump noise but no water check the nozzles, pipework, and the inline one way valves, the rear one way valve is located in the rear roof space, if you locate the waterpipe at the rear door opening and gently pull the gromet out on the body side, about 6 inches down is a oneway valve that gets full of gunge, remove and blow clear.
how to:
if you have 2 batteries remove the nearside one with the usual care of short circuit. remove the batt tray.remove the front grill, remove the nearside headlight/sidelight. remove the 2 10mm bolts thet hold the top edge of the washer res to the slam panel, lift the res upwards, the res is now free but still connected to the pipework at the lower edge,and the lecky bits.
you may have to move wiring harnesses to lift enough to work on the pumps.
remove the pump/s:
they are just push fit into the res so gently lever away from the body,they are held watertight with a rubber gromet. free the lecky plug/s.
the plugs are different but may be swapable if you follow the guide below and remove the lecky connection part and swap over,but this needs to be confirmed as ive only stripped the rear wash pump.
piscs 1 and 2 show the removed rear wash pump. if you gently pull on the lecky conection block it will pop out, its held in by a rubber ring, and the springs that rub on the com, just pull evenly.
pics 3-4 show the inner bits/com,this will prob be full of crud and mine was siezed solid. wash out with penetrating spray or similar. i had to gently rotate the shaft/com using a very small screwdriver by levering against the com and the side body, once some movement was obtained more spray to wash out the crud, repeat until its really smooth to rotate, final wash out then move to the lecky contacts on the plug bit, just a light degunge with some light emery cloth and a wash off then gently push back together making sure the brushes go one either side of the com, lubricate the sealing ring and snap back together, job done.
back together: note the dirrection the plug should face.
dont be tempted to remove the white plastic base,it looks like it may come off but it may be destroyed in the proccess. #-o
to rebuild the motor to the bottle push the ruber gromet into the res first, then gently but firmly push the motor through the gromet until it snaps into place,(lub first).
test the motor before you remount the res and rebuild the front of your bongo.
should take a couple of hours start to finish.
good luck.
coffee and bacon sandwiches provided by northern bongolow :D :D :wink:
B*Witched Blingo
Re: Servicing failed Windscreen Washer Motor With Pics
Post by B*Witched Blingo » Sun Jan 15, 2012 10:45 pm
Thank you. :D :wink:
You Tube Films Click Here
Post by Doone » Sun Jan 15, 2012 10:56 pm
=D>
A great post, I've added it to the FAQ forum so we will always be able to find it.
Post by Simon Jones » Sun Jan 15, 2012 10:57 pm
Fair play for having a go at repairing it. I cheated and got one from a breakers. Annoyingly I chucked the old one away, but it looks like it could have been saved. That'll teach me for throwing something away #-o.
Post by Northern Bongolow » Sun Jan 15, 2012 11:01 pm
not like you simon :shock: :D :D . if you get a chance, try swopping the lecky block terminals over, then you only need one spare.
edit to the top post, should be 10mm and 12 mm sockets #-o #-o :)
Last edited by Northern Bongolow on Sun Jan 15, 2012 11:06 pm, edited 1 time in total.
Driver+Passengers
Post by Driver+Passengers » Sun Jan 15, 2012 11:03 pm
With permission, I've copied this to the Wiki too.
http://mazdabongo.wikispaces.com/Servic ... sher+motor
Image Image
Post by Ian » Sun Jan 15, 2012 11:37 pm
.....and I'll also make it a fact sheet on main website if that's OK.
Post by Northern Bongolow » Mon Jan 16, 2012 3:07 pm
ooohhh go on then. 8) 8) :lol: .
edit.
had a look at the front screen washer motor and the electrical block is removed in the same way, so although its white in colour it appears to be constructed the same, apart from the dirrection of the nozzle to the delivery pipe, but this is easy to get round as there is enough slack pipe to reach, or just extend the pipework by a few inches.
MountainGoat
Re: Service failed Windscreen Washer Motor with Pics DONT DE
Post by MountainGoat » Mon Jan 16, 2012 6:46 pm
Impressive. =D> =D> =D> But then that's Ady. Talk about fiddling while Rome is burning. :-({|= :-({|= :-({|= Ady would be messing about with his Bongo while his house was falling down. #-o #-o #-o
Tony
B*Witched Blingo
Post by B*Witched Blingo » Mon Jan 16, 2012 7:25 pm
Hey.. Don't mention messing around and houses in the same sentence. It's the norm to have half a Bongo engine in the lounge. Aaargh......... :evil:
Bacon Butty anyone :lol:
Post by Northern Bongolow » Tue Jan 17, 2012 5:07 am
sssssssshhhhhhh tony, the boss hasnt noticed that the pics were taken on the new dining table-------just a few scratches and a bit of paint, i will just blame the kids :oops: :oops: :wink:
jaylee
Post by jaylee » Tue Jan 17, 2012 9:38 am
Good handy tip Ady.. Will remember that for the future reference. :D
.... The only problem i see in my case regarding this kind of practice..? :? :?
Is i'll have to blame someone else's kids...!! :wink:
dblake
Post by dblake » Thu Jan 19, 2012 11:40 pm
Used this today to repair my rear washer and replace my front one :-)
Cheers!
Post by Northern Bongolow » Fri Jan 20, 2012 4:14 am
glad it helped :) .
i love a cheap fix meeeeee :lol:
thedogsbollox
Post by thedogsbollox » Sun Apr 08, 2012 3:30 pm
Cheers Ady mate. Had the front washer pump fail on me today and whipped all out and back in again in 2 hours including cleaning up both pumps.
One footnote though, it was not necessary to remove either the headlight or the grill. Just the leisure battery tray which was only 4 bolts.
Thanks again for explaining things so very well. Now i am off to Norfolk tomorrow.
Tony
