What should I do first
al & chris
Post by al & chris » Tue Oct 09, 2012 3:25 pm
Rear arches rusting get them done or get a proper waxoil job done on van first. Should have had wax oiled years ago. Don't know what to do first?
briwy
Re: What should I do first
Post by briwy » Tue Oct 09, 2012 3:34 pm
I'd get the arches done first.
If you do the waxoyling there could be a fire risk when the welding is done on the arches and it will have to done again once the new ones are fitted.
I can give you the place we had ours done near Matlock if you want a recommendation not too far away.
Post by Ian » Tue Oct 09, 2012 3:49 pm
How much did you pay for the whole job, Brian?
briwy
Post by briwy » Tue Oct 09, 2012 3:56 pm
Couple of years ago now Ian but I think it was about £450 excluding the Transit panels which I got for £20 the pair from the place in Doncaster. One of them had a big dent in it which didn't matter as that part was chopped off anyway.
He made some new bits for the inner arches as well as fitting the outer ones.
