Hi all
New to the forum and looking to buy a Bongo.
Have a few questions hope somebody can help.
Drove a Bongo this weekend and its fantastic, but a few niggles.
Left it tickover for 20 minutes and the top hose got very hot, is this normal?
And i think it has a low coolant alarm fitted but i could not hear any bleeps or see any flashing light, does this sound right?
The owner said it has had a new cylinder head in the past and has 141,000 on the odo, is this miles or klms
Sorry for all the questions on my first post but i dont want to buy a heap of trouble.
If someone can shed light on the above i would be very grateful.
Thanks in advance
Help needed
- widdowson2008
Re: Help needed
Yes - perfectly normal. The top hose carries coolant directly from the cylinder head so this is coolant at its hottest.germag wrote:Hi all
Not competent enough myself to answer your other questions but someone will be along shortly who does know the answers.
Steve
Re: Help needed
Thanks for that Steve.
Re: Help needed
If the owner says that it's had a cylinder head then the owner will have a reciept for between 12 to 1500 ££££££germag wrote:Hi all
Thanks in advance
If in doubt then walk away there is plenty to chose from
Re: Help needed
Low coolant alarm should beep and flash for a second when you turn on the ingition, then be silent if all is well.
Welcome aboard.
Welcome aboard.
Re: Help needed
Did,nt think of asking for receipt.
Thank you both for the info.
Gerald
Gerald
Re: Help needed
Haydn's device does but the other design that used a float chamber and appeared on Ebay doesn't give a test bleep.Bob wrote:Low coolant alarm should beep and flash for a second when you turn on the ingition, then be silent if all is well.
