Expansion tank capacity
Blueskai
Post by Blueskai » Sun Aug 19, 2012 11:31 pm
I've been tinkering and flushed my coolant system. A necessary job as I replaced one of the metal pipes. Having a few issues
The tank was at a good level when hot at 6pm, but I just added about 400ml as it had dropped. Would this amount of loss take it below the expansion pipes and therefore require another bleed?
widdowson2008
Re: Expansion tank capacity
Post by widdowson2008 » Mon Aug 20, 2012 11:07 am
Blueskai wrote:I've been tinkering and flushed my coolant system. A necessary job as I replaced one of the metal pipes. Having a few issues
All depends on what you mean by 'a good level'.
The difference between volume of coolant at the 'Hi and Lo' level marks is approx 600ml.
The difference between 'Lo' mark down to the entry/exit pipes (danger point) is 360ml.
So, in answer to your question, it all depends on what you refer to as 'a good level'.
Steve
teenmal
Post by teenmal » Mon Aug 20, 2012 11:58 am
Another bleed will do more good than harm :) It would appear that you left some air in the system when you bled it.
Cheers.
Post by Northern Bongolow » Mon Aug 20, 2012 8:52 pm
if you bled it using the you tube method its best to leave it 15-20mm above the full line when you cap it off, then when its cool in the morning it should be bang on the full mark when cold.
