Hi There bongoers
Our bongos wheel bearing (front passenger) went so we ordered the new bearing 80mm 45mm 42 mm, but when we came to fit it, the old bearing is a size 70mm x 30mm?? so can any one shed some light on this and where can i get one from quickly as we are supposed to go away weds lol. Many thanks to all for reading...Dave and Kim.
Wheel bearing madness please help
Re: Wheel bearing madness please help
You should get one here,worth checking with the supplier the pysical size,I have heard of spurious sizes of these bearings.
IE 2wd and 4wd
http://mazdabongo.com/display.productse211.html?cId=91
IE 2wd and 4wd
Hi thanks for the link I will ring them first thing 2mo with the correct size any other info would be gladly appreciated. Many thanks again.
Hi bigworm,
The Bongo Fury Shop also sells the bearings.
Cheers..
Cheers..
