Wheel bearing madness please help
bigworm
Post by bigworm » Sat Aug 18, 2012 2:24 pm
Hi There bongoers
Our bongos wheel bearing (front passenger) went so we ordered the new bearing 80mm 45mm 42 mm, but when we came to fit it, the old bearing is a size 70mm x 30mm?? so can any one shed some light on this and where can i get one from quickly as we are supposed to go away weds lol. Many thanks to all for reading...Dave and Kim.
rita
Re: Wheel bearing madness please help
Post by rita » Sat Aug 18, 2012 4:52 pm
You should get one here,worth checking with the supplier the pysical size,I have heard of spurious sizes of these bearings.
IE 2wd and 4wd
http://mazdabongo.com/display.productse211.html?cId=91
bigworm
Post by bigworm » Sun Aug 19, 2012 10:45 am
Hi thanks for the link I will ring them first thing 2mo with the correct size any other info would be gladly appreciated. Many thanks again.
teenmal
Post by teenmal » Sun Aug 19, 2012 12:45 pm
Hi bigworm,
The Bongo Fury Shop also sells the bearings.
Cheers..
