Dr Fingers
Post
by Dr Fingers » Mon Jul 02, 2012 2:59 pm
Can anyone enlighten me? What size 'O' rings are used on the two condenser units? Apparently there are upto 40 + possible sizes that they might be
Many thanks
Derek
Post
by g8dhe » Mon Jul 02, 2012 3:46 pm
There appear to be 3 sizes used in all;
http://lushprojects.com/bongopartsmk2/c ... no=.html#1
if you use a google search on the part number (first column in the table) you sometimes get lucky and get sizes!
Dr Fingers
Post
by Dr Fingers » Mon Jul 02, 2012 7:29 pm
Thank you so much!
Now to try and find some..
Derek
Post
by Ian » Mon Jul 02, 2012 7:53 pm
They are easily obtainable. I have a couple in stock and can get hold of the others. The ones I have in stock are 61-J1XA & 76-754E. These are the most commonly requested ones and can be found on this page:
http://www.lushprojects.com/bongopartsm ... no=.html#5
Post
by g8dhe » Mon Jul 02, 2012 7:56 pm
Another solution is
http://cpc.farnell.com/rolson-tools/612 ... lson+61225 which at £6.55+P&P (wait for a free weekend P&P offer!) and you have a good range of possible sizes at low cost!
Dr Fingers
Post
by Dr Fingers » Mon Jul 02, 2012 8:16 pm
Ian wrote:They are easily obtainable. I have a couple in stock and can get hold of the others. The ones I have in stock are 61-J1XA & 76-754E. These are the most commonly requested ones and can be found on this page:
you have PM.
Derek
Dr Fingers
Post
by Dr Fingers » Mon Jul 02, 2012 8:20 pm
Sorry Ian, can't see a link to PM you..(?)
Derek
Post
by francophile1947 » Mon Jul 02, 2012 8:51 pm
Derek
Send him an email
[email protected] - he often has his PMs turned off, so that he can get some peace
Simon Jones
Post
by Simon Jones » Mon Jul 02, 2012 9:15 pm
When I changed mine, the aircon specialist I saw said you had to use special ones designed to withstand the pressure and the chemical reaction with the refrigerant, so it may be that these would not be suitable.
Post
by g8dhe » Mon Jul 02, 2012 11:00 pm
MRD applies
If you like them with green-felt tip around the edges then not a dissimilar price here
http://www.ebay.co.uk/itm/R134A-AIR-CON ... 0689925232
helen&tony
Post
by helen&tony » Tue Jul 03, 2012 7:23 am
Coo....ask the man who has everything!...I'll be in contact, Ian...I have to strip the rear heater box and put a new matrix in, so I have to get some of those seals
teenmal
Post
by teenmal » Tue Jul 03, 2012 10:31 am
Dr Fingers
Post
by Dr Fingers » Tue Jul 03, 2012 12:14 pm
Thanks, but it's the sizes that I'm trying to find out. Tried a couple of sites, but get messages back saying part numbers not recognised..
Derek
steveyd
Post
by steveyd » Wed Jul 04, 2012 11:40 am
Got exactly this problem right now on the rear unit - I kept the old o-rings and placed them nice and safe on the window sill for reference when ordering new ones - but they've dissappeared. I have pushed some blue-tac onto the pipes to get an idea of size (dont have it with me for measuring) but after some extensive googling found this site:
http://www.altecweb.co.uk/home.asp?rf=ggl&cat=RangeB05 which is a bit cheaper than this:
http://www.autoairparts.co.uk/mazda-o-r ... 7097-p.asp
.. one thing I'm not sure of is whether they are nitrile or not.. they do/did look sort of shiny like the nitrile ones in the pictures (not green).
I did try and pull the o-rings out of the connections for the funny valve thing on the old aircon rear matrix but they were different sizes. I'm going to order some from one of the sites above - if I get a selection I will hopefully hit the jackpot.. and report back here! (this has come up a few times!)
cheers,
Steve
Simon Jones
Post
by Simon Jones » Wed Jul 04, 2012 10:42 pm
On mine, I removed the original black ones and replaced with the green ones. Somewhere, in a envelope in a really safe place, I do have the ones I removed, but I'm damned if I can find it right now. Will try to have a rummage tomorrow if time allows.
