THAT BLOODY COOLANT THING AGAIN
tboy
Post by tboy » Sun Jun 10, 2012 9:13 pm
Header tank below low level when cold.Water in neck below header tank.
When engine run for 10 minutes or so water level sometimes re establishes to mid level.sometimes,does not boil?
Top hose hot radiator matrix cool.baffling the pooh out of me.
Radiator looks new.wonder if it is the infamous bleed reqd
No other sympthons
daveblueozzie
Re: THAT BLOODY COOLANT THING AGAIN
Post by daveblueozzie » Sun Jun 10, 2012 9:18 pm
Coolant should be on line with the high level not the low level when cold.
Lost without my Bongo.
Post by francophile1947 » Mon Jun 11, 2012 12:28 pm
Top hose always gets hot - the bottom hose only gets hot when thermostat opens. I found that my bottom hose rarely ever got hot during normal running'
I could never get my coolant to stay at the full level, it always settled around halfway between full and low when cold - never had it go below the low mark though, so you may have a leak or, as you say, it may need bleeding properly.
tboy
Post by tboy » Tue Jun 19, 2012 5:49 pm
System checked by local garage.Pinned it down to shot water pump.Pump changed all seems good.
daveblueozzie
Post by daveblueozzie » Tue Jun 19, 2012 5:52 pm
Hope its been bled properly :shock:
tboy
Post by tboy » Tue Jun 19, 2012 6:29 pm
They say yes.done a few.I will have to trust their honesty and professionalism.Stand by for update
