help needed.......again :(
8etty 8ongo
Post by 8etty 8ongo » Sun May 13, 2012 2:58 pm
hi all
hubby is trying to fix an oil leak and has discoveredsomething that is broken, but we dont know what it is. the photos are taken of under where the middle console goes and are taken from the drivers side. have tried to circle the bits in the photos that are broken. looks like some kind of tubing has split and also has broken off from where it is meant to be.
hope someone can help and advise...
have circled the bit in this pic and you can see the tubing to the right of it that looks like it should be attached
in this pic i have circled both bits together which i think re meant to be attached
this pic again shows the tubing which also has a split in it as as well as the break
this pic is just a closer up one of the bit
can anyone help and tell me what it is?
stefan442
Re: help needed.......again :(
Post by stefan442 » Sun May 13, 2012 3:16 pm
Mine is broke and it don't seem to have any negative impacts.
This post may help a bit...
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=50170
rita
Post by rita » Sun May 13, 2012 3:18 pm
Hi its the check valve for the vacuum solenoids
13-995
http://lushprojects.com/bongopartsmk2/c ... f02.html#4
8etty 8ongo
Post by 8etty 8ongo » Sun May 13, 2012 6:34 pm
rita wrote:Hi its the check valve for the vacuum solenoids
13-995
hi, thanks for that, where would i get a replacement and what kind of job is it to do?
thanks
8etty 8ongo
Post by 8etty 8ongo » Sun May 13, 2012 6:36 pm
stefan442 wrote:Mine is broke and it don't seem to have any negative impacts.
hi, how long has yours been broke. good to know that its ok but would prefer to fix if not to costly and difficult [-o< [-o<
stefan442
Post by stefan442 » Sun May 13, 2012 8:14 pm
I have only had the bongo just over a month. I only noticed it when I was cutting in a fuel cut off switch, it could have been broken for months. I will get it fixed at some point, but i don't even know if my egr is functional! Will take it to bell hill and get a professional opinion at some point!
Post by Northern Bongolow » Sun May 13, 2012 9:14 pm
any mazda with egr on them has the same part, scrap yard job.
its a one way valve.
8etty 8ongo
Post by 8etty 8ongo » Sun May 13, 2012 10:56 pm
Northern Bongolow wrote:any mazda with egr on them has the same part, scrap yard job.
sorry but what is egr?
Post by Northern Bongolow » Mon May 14, 2012 2:02 pm
its exhaust gas recirculation. its a way of cleaning up the emissions, this egr is not needed for the uk regs, and most dont work now as some bongo's are getting on a bit. if yours is still working you may need to repair/replace the part thats broken.
this is a one way valve that is linked into the air pipe circled.if this is broken it may suck air into the system bypassing the filter, and may whistle. the vacuum system may also leak and affect your cold start operation.
widdowson2008
Post by widdowson2008 » Mon May 14, 2012 2:12 pm
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=50170[/quote
Wondered where that post had gone (I was never any good at searching through old posts though :oops: )
Back to the 'FIX'. We did spenners head AND this broken pipe exactly 12 months ago and it's still in one piece, so the fix worked. and it's VERY EASY to do.
Steve
Post by Northern Bongolow » Tue May 15, 2012 4:34 am
steve betty's is broke the otherside of the valve to yours (spenners), it looks like the valve itself has broke, a little more cunning may be needed to sort this. :wink:
widdowson2008
Post by widdowson2008 » Tue May 15, 2012 10:47 am
Northern Bongolow wrote:steve betty's is broke the otherside of the valve to yours (spenners), it looks like the valve itself has broke, a little more cunning may be needed to sort this. :wink:
Oh - Right. Cunning is certainly called for then. Any ideas?
Steve
Post by Northern Bongolow » Tue May 15, 2012 12:51 pm
yes :) get one off a breaker or any petrol mazda of the same age with egr on it.
