Another dribbling pipe.......HELP.........
Bongo??
Post by Bongo?? » Wed Apr 11, 2012 10:15 pm
Hello all..
Whilst putting the Bongo back together i noticed a small damp patch on the concrete below the rear air-con system pipes.
On further inspection it appears that the smaller pipe has a tiny hole,so small you can barely see it,which was covered by a white plastic bracket,the bracket which fixes the 2 air-con pipes and water pipe from the rear heater matrix.
The faulty pipe has a connection on the passenger side and theres a connection where it oes into the floor to the rear AC system.
Does anyone know where i could get one,i`m currently searching the net.....
Or could it be repaired??
If you watch the pipe it tends to blow a little bubble and then pops and drips,i thought AC was gassed,so why does it drip??
THANKS AGAIN PEEPS.................... :roll:
Year 2000 V6
Re: Another dribbling pipe.......HELP.........
Post by g8dhe » Wed Apr 11, 2012 11:01 pm
You have a heater coupled to the cooling system, and an air con. feed to cool the air, so you have both sets of pipes kicking about there;
Rear Heater: http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Rear Air Con.: http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Bongo??
Post by Bongo?? » Wed Apr 11, 2012 11:10 pm
g8dhe wrote:You have a heater coupled to the cooling system, and an air con. feed to cool the air, so you have both sets of pipes kicking about there;
Spot on m8,thats the diagram i was trying to find....CHEERS..... :D :D :D
Year 2000 V6
stefan442
Post by stefan442 » Wed Apr 11, 2012 11:14 pm
I'm guessing it drips due to condensation?
Simon Jones
Post by Simon Jones » Wed Apr 11, 2012 11:38 pm
Is it the thin metal pipe? There is a bright green liquid / dye in the aircon which is part of the lubrication for the compressor. It will naturally tend to end up at the lowest part of the system by the rear unit. If you are lucky it's one of the o-rings is on its way out, but I expect it's the aluminium pipe that has become slightly porous. I've seen this before and it ran fine for several years with only one regass in that period. As long as the aircon is nice and cold, then I would personally leave well alone.
Bongo??
Post by Bongo?? » Thu Apr 12, 2012 9:10 pm
Simon Jones wrote:Is it the thin metal pipe? There is a bright green liquid / dye in the aircon which is part of the lubrication for the compressor. It will naturally tend to end up at the lowest part of the system by the rear unit. If you are lucky it's one of the o-rings is on its way out, but I expect it's the aluminium pipe that has become slightly porous. I've seen this before and it ran fine for several years with only one regass in that period. As long as the aircon is nice and cold, then I would personally leave well alone.
Yeah,it`s the small pipe,had it in my local garage today,it`s going to be sortable....they`ll do it when the Cam belt`s done.....that`s a few quid....... :shock: :shock: :shock:
Year 2000 V6
