Hold Light comes on
DaveyJ1965
Hold Light comes on
Post by DaveyJ1965 » Thu Mar 29, 2012 9:26 pm
Whilst driving the HOLD light came on and flashed at a constant rate the vehicle stayed in third gear. Stopped filled it up with fuel (as I was running on fumes) and restarted it no problems, drove it home (approx 5 miles) still no problems. Just switched it on again and then started it expecting the the HOLD light to flash the fault code but it didn't. any ideas I assume it will come back. I have only had this one a month it is a yr 2000 V6 Freda. Feeling a bit concerned.
321Away
Re: Hold Light comes on
Post by 321Away » Fri Mar 30, 2012 2:58 pm
Flashing hold light indicates a transmission fault, you'll have to read the code for an accurate description.
http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
julian
