Does anyone know how many teeth there are on the NE / Crank sensor???
Muchas Ta!!!
NE / Crank sensor
- helen&tony
NE / Crank sensor
Re: NE / Crank sensor
pm sent.
- helen&tony
I'm told that the NE sensor is likely a VR sensor...is it 2 or 3-wire?
Thanks in advance
Thanks in advance
The NE Sensor is shown as being 2 wire;
I think you will find all the NE (Crankshaft) sensors will be Variable Reluctance type, the Cam shaft (B4-18 or B4-21) sensors are also magnetic but might be of the type where the magnet is on a disk/gear as they are built into the distributor on the petrol types, again 2 wire according to the wiring diagrams
- helen&tony
Thanks for the info. Geoff...that may help a lot!
