tappy engine
marsden26
tappy engine
Post by marsden26 » Wed Mar 07, 2012 11:32 am
Can anyone give any advise here.i hava a 2.5 diesel 4 wheel drive,a new cylinder head was fitted last year and its been fine no problems but i have noticed in the past few weeks its sounding like its got noisey tappets,the levels are fine and it had a service last november.has anyone else come accross this.
wonkanoby
Re: tappy engine
Post by wonkanoby » Wed Mar 07, 2012 11:34 am
just get them reset?
haydn callow
Re: tappy engine
Post by haydn callow » Wed Mar 07, 2012 12:01 pm
After fitting a new head the valves/tappets etc will "bed in" and should be readjusted after a few hundred miles.
http://www.coolantalarm.co.uk
Also BMW Clocks
MountainGoat
Re: tappy engine
Post by MountainGoat » Wed Mar 07, 2012 2:13 pm
Check out one of my previous posts:
Hi Stuc, not being much of a mechanic myself all I can tell you is that I had my tappets adjusted at a garage in Edinburgh in November 2010 after Ady told me that they sounded a bit noisey. The garage was recommended by Dandywarhol. Cost me £17.25 + vat from Bongobits for the gasket set and I was charged £60.00 all in by the garage for the job which took about an hour.
The torque settings and the tightening sequence are in the workshop manual. I can PM you them if you need them.
I was told by the mechanic that three of my tappets were a tad loose. :shock: Bongo sounds great now. Bongo club shop also sells the gasket set that you will need for the job.
Tony
