starting problems
- peanutcrusher
- Tribal Elder
starting problems
anyone got any idears
i have been out and tryed to start the bongo this morning its been stood for around a week. there is charge in the battery and the enging turns over it seems to go to fire up but just will not start
its a 2.5 diesel on a p plate if that helps.
i have tryed to turn the key wait for the click then turn the key off and back on again so as to make sure the glow plugs are warm.
it has been throwing out a fair bit of white smoke when i got it started of late but i guessed that was just hte time of year.
Bongo now work later !!!
Re: starting problems
how old are the glow plugs
Almost certainly glow plugs, if it runs OK after a couple of minutes.
- peanutcrusher
- Tribal Elder
check they are getting power
but they could still be duff
- peanutcrusher
- Tribal Elder
meter or evan a bulb to the rail connects them and an earth
- peanutcrusher
- Tribal Elder
i've had a friend look at the van the glow plugs are fine it seems to be losing fuel pressure he thinks. its started now once its started the once its ok it only when its left it seems to play up.
there seems to be some diesel round the top of the engine as well.
M 80NGO
Read page 4 buddy, http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=53672
my cold start was set to idle to high, don't press the throttle at all as the ecu will turn the glowplugs off
M 80NGO
Sorry page 3M 80NGO wrote:Read page 4 buddy, http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=53672
Are you using Vegi oil?
look for a fuel leak around the return links at the injectors, is your glowplug buss bar touching on the link pipes, and has burned/rubbed through.
