Window switch bulbs
winchman
Window switch bulbs
Post by winchman » Thu Feb 09, 2012 8:45 pm
I asssume the electric window switches in the doors light up?
If so how do I remove them to change the bulb?
Dabs
Re: Window switch bulbs
Post by Dabs » Thu Feb 09, 2012 8:57 pm
winchman wrote:I asssume the electric window switches in the doors light up?
No lights unless you put leds in yourself!!
mentaliss
Post by mentaliss » Thu Feb 09, 2012 9:05 pm
_____________________________________________________________
yep! doing that right now
winchman
Post by winchman » Thu Feb 09, 2012 9:43 pm
How?
Could we have a picture please?
jaylee
Post by jaylee » Thu Feb 09, 2012 10:00 pm
Done mine a good while back too... Set up the wiring when i installed the remote CL & window roll up module...
I got a switch out of a 626 as a replacement.. The original was butchered by the previous Jap owner..
The cameras a bit sensitive, but in the dark...
I also got it to go red when i hit the panic button, the van locks down & the windows roll up... The 626 rocker switch is wired different to the Bongo's
Post by Northern Bongolow » Fri Feb 10, 2012 3:14 am
very posh =D> =D> :wink:
mentaliss
Post by mentaliss » Fri Feb 10, 2012 10:01 am
winchman wrote:How?
jaylee's job sounds better than my ideal as he's used back lit switches im using miniture LED (blue) fitted (drilled) into the indentations of the switch cover, new micro wiring from the LED's through the doorway into the cab eventually linking up to the sidelights, Im not sure if Jaylee's ideal is easier work wise than mine he sounds like he has a sound understanding of electronic's so if I had'nt started mine my way I would have adopted his ........ but at the moment its far too cold to carry on with the work!
jaylee
Post by jaylee » Fri Feb 10, 2012 10:27 pm
mentaliss wrote:
winchman wrote:How?
I just bunged a couple of spare LEDs in the gap so as not to foul the switches....
I'm looking forward to seeing you end result Mentaliss...
8) 8)
Mine was wired from the live into the dash back-light loom & earthed in the door..
It was a bit of a fiddle, but i was reparing the door loom anyway..!
:lol: :lol: Not really, i just get an idea & go for it... But fun learning.!
