BMW clock connection
Hello
I cant find this by searching so can some one tell me the correct way to connect this up as I cant tell which wire is live etc
- haydn callow
Re: BMW clock connection
Red/Yellow=Permanant live (clock)
Brown=Earth
The other wire=switched live(clock light)
Brown=Earth
Thankshaydn callow wrote:Red/Yellow=Permanant live (clock)
Brown=Earth
haydn also changes the bulb colour and the face plate colour if desired, dont you haydn.
- haydn callow
all part of the service !!
Now for my next question how do I change it from orange to green?
- haydn callow
This involves pulling the clock to bits....removing the orange filter and putting in a green LED (polarity sensitive)
Or send just the clock to me with £7.50 and I will do the job and post back.
Thanks I will have a go.haydn callow wrote:This involves pulling the clock to bits....removing the orange filter and putting in a green LED (polarity sensitive)
I did find a BMW digital clock in the scrappy, but cant get it to light as its got 4 wires? Any ideas?
If its anything like the gauges i fitted? It will have two wires for the negative & positive of the actual clock.. Then the other two Positive to the dash light loom & the other to ground... Designed to back light with the dash when the sidelights come on...?
What are your clock four wire colours...?
- haydn callow
winchman wrote:Thanks I will have a go.haydn callow wrote:This involves pulling the clock to bits....removing the orange filter and putting in a green LED (polarity sensitive)
Have fun....easy to damage it.
Being an engineer I have broken far more expensive things than a BMW clock LOLhaydn callow wrote:winchman wrote:Thanks I will have a go.haydn callow wrote:This involves pulling the clock to bits....removing the orange filter and putting in a green LED (polarity sensitive)
I did get two incase I had an accident.
The digital one I can get to light up but just displays zeros?
- Driver+Passengers
If you leave it on for just over a minute, does it say "00:01"?winchman wrote: The digital one I can get to light up but just displays zeros?
Hey you had me thinking then LOLDriver+Passengers wrote:If you leave it on for just over a minute, does it say "00:01"?winchman wrote: The digital one I can get to light up but just displays zeros?![]()
No it dosnt and the buttons dont work either
Hang on a minute, its started its now on 00:01 no its 00:02.
So how do we explain that?
- Driver+Passengers
Maybe you took her up to 88mph...winchman wrote:Hey you had me thinking then LOLDriver+Passengers wrote:If you leave it on for just over a minute, does it say "00:01"?winchman wrote: The digital one I can get to light up but just displays zeros?![]()
Hey Winchman, it wouldn't happen to have an exterior temp gauge on the readout too would it??
I got hold of something similar from a 626, but gutted it for a temp gauge for the coolant...
