factory fitted immobiliser ...flashing but no beeps
toastedfrog
Post by toastedfrog » Tue Jan 31, 2012 7:12 pm
Hi wonder if anyone can help ..i have a 2.5 friendee with factory fitted immobiliser. The imobilser flashes in normal manner however when i place fob into in it doesnt beep, allowing me to start the engine??
my partner tried disconnecting battery for 10/15 minutes hoping to reset it, this didnt work!
could anyone shed some light on this problem as its worked fine yesterday.
toastedfrog
Re: factory fitted immobiliser ...flashing but no beeps
Post by toastedfrog » Tue Jan 31, 2012 8:20 pm
We had to recently remove the radio due to the electric kept tripping ...since then everythings run fine until today!
Is there any way to bypass the immobilser? ..i also have a peugoet 306 and the keycode box is disconnected, is there any way to remove the immobiliser???
jaylee
Post by jaylee » Tue Jan 31, 2012 8:45 pm
OK, i'll bite on this one..... 8-[ :mrgreen:
Hi Toastedfrog.. Do you have a leisure battery fitted..? (A second battery under the bonnet on the passenger side, used for camping..)
toastedfrog
Post by toastedfrog » Tue Jan 31, 2012 9:01 pm
Hi, no i havent got a leisure battery!
jaylee
Post by jaylee » Tue Jan 31, 2012 9:09 pm
What state of affairs was the radio wiring in when the radio was removed....? Would you say it looked a little "botched up"?
...I'm thinking the two maybe linked..?? & yes it should be possible to bypass the immobilizer loom..!
jaylee
Post by jaylee » Tue Jan 31, 2012 9:11 pm
Geoff, help us out..!?? :wink: I just been perusing the wiring diagrams... :lol:
Post by g8dhe » Tue Jan 31, 2012 9:12 pm
toastedfrog wrote:We had to recently remove the radio due to the electric kept tripping ...since then everythings run fine until today!
When you say it kept tripping do you mean blowing the Fuse ? If so which one, there are two fuses that power the radio, and its quite likely that the Immobilser will use the permanent feed itself which is this one, so it might be worth checking it;
P.S just seen your post Jaylee whilst I was preparing this ;-)
jaylee
Post by jaylee » Tue Jan 31, 2012 9:16 pm
I was wondering if it was the radio permanent live "memory setting" fuse..?
Toastedfrog, does yer cabin lights come on when you open the door...? Do the cabin courtesy lights work at all..??! (On the same circuit.)
jaylee
Post by jaylee » Tue Jan 31, 2012 9:22 pm
Fuse 1 also has something to do with the ECU if i remember right too..?!!
Post by g8dhe » Tue Jan 31, 2012 9:24 pm
Yup it powers most things that need a permanent supply, however I think the only thing the ECU uses the permanent supply for is to remember the last error number, but don't quote me on that :cry: Not having seen a circuit for any of the ECU's I'm only guessing!
toastedfrog
Post by toastedfrog » Tue Jan 31, 2012 9:29 pm
the trouble we were having was with the 1st fuse as pictured ..which everytime tried to replaced the fuse while sterio was in place it blew..removed sterio and it allowed the fuse to be replaced!
yes the inertior lights are all still workin ..just no dash light when the keys turned
jaylee
Post by jaylee » Tue Jan 31, 2012 9:30 pm
g8dhe wrote:Yup it powers most things that need a permanent supply, however I think the only thing the ECU uses the permanent supply for is to remember the last error number, but don't quote me on that :cry: Not having seen a circuit for any of the ECU's I'm only guessing!
I'm pretty certain when i pulled that fuse & forgot to replace on a "project" not only did i loose radio memory settings & cab lights, when the engine was running the glow plug light flashed too..! Or maybe it was the hold light..?
jaylee
Post by jaylee » Tue Jan 31, 2012 9:36 pm
toastedfrog wrote:the trouble we were having was with the 1st fuse as pictured ..which everytime tried to replaced the fuse while sterio was in place it blew..removed sterio and it allowed the fuse to be replaced!
I personally would be looking at what's causing the short with the radio to start with....
Is there anyway you can check the state/charge of the starter battery..?
toastedfrog
Post by toastedfrog » Tue Jan 31, 2012 9:45 pm
the radio was removed last saturday, and has been used daily since then, up until this afternoon ..how would i go abt working out what could have been tripping the sterio?
when the fuses were blown it effected the glow plug light (contiually flashing) the doors open light, the internal lighting, and central locking. it then stopped the alternator from charging the battery ...leadin me to be jumped started ..until the radio was removed!
jaylee
Post by jaylee » Tue Jan 31, 2012 9:56 pm
jaylee wrote:What state of affairs was the radio wiring in when the radio was removed....? Would you say it looked a little "botched up"?
toastedfrog wrote:the radio was removed last saturday, and has been used daily since then, up until this afternoon ..how would i go abt working out what could have been tripping the sterio?
Look for dodgy wiring connections bare wire/s on the loom leading to the radio in the din slot/place where the radio goes...? :idea: :arrow:
Was it just a head unit, or do you have an amp fitted too..? With all that sub bass stuff..!
