Identification of Parts (WL-T)
Re: Identification of Parts (WL-T)
Sterling work there Matt. I wish I'd taken more photos when I've been doing the 'oily bits'
- daveblueozzie
Matt I still think that you should find somewhere to add Kirsty's full list of Bongo coolant hoses. It has been posted on the forum a few times now.
Tony
Tony
- Driver+Passengers
On page 3 of membersonly/factsheets/hoses.pdfMountainGoat wrote:Matt I still think that you should find somewhere to add Kirsty's full list of Bongo coolant hoses. It has been posted on the forum a few times now.
Tony
viewtopic.php?f=3&t=41120#p417702
viewtopic.php?f=3&t=45557#p464392
Great stuff! The lushprojects.com part numbers are probably the best way to tie things together - not sure I even need to do anything other than link to Kirsty's list!
- Driver+Passengers
I've been updating the images on the wiki so the links I used on this thread are no longer valid, hence no images in the first two posts anymore. Might ask a mod nicely to edit the links once I've stopped adding stuff. Otherwise, just go to the wiki - there should be more on there.
Matt
Matt
- Bongonaut
Just (20may15) tried to access the 'wiki' links and it says wiki subscription expired. Any chance they could be made available again somehow? Thanks.
Never drive faster than your angel can fly!
It is no more.
Fear not (yet) - I am in the process of investigating options to resurrect it, and the original pages are still stored away for re-birth.
Watch this space
DA
Watch this space
DA
- Driver+Passengers
Found an old copy of one of the images...
![Image](http://i1224.photobucket.com/albums/ee365/Driver_and_Passengers/Enginebayviewoffsidev01lowres.jpg)
1. Air filter housing
2. Fuel filter body
3. Power steering fluid reservoir
4. Automatic Transmission Fluid (ATF) dipstick
5. Throttle Position Sensor (TPS)
6. Temperature Sender
7. (Blanked) Exhaust Gas Recirculation (EGR) joint
8. Intake manifold elbow
9. Vacuum advance tube thingy
10. Coolant hose
11. Throttle Idle switch
12. Cold start actuator
13. Throttle cable adjuster
14. Diesel fuel pump
15. Intake manifold
16. Fuel pipes bracket
17. EGR vacuum tube thingy
18. Center cowl
19. Fuel injector (1 of 4)
20. EGR vacuum solenoid
21. Vacuum solenoid
22. Vacuum solenoid
23. Rocker cover
24. Glowplugs bar thingy
2. Fuel filter body
10. Coolant hose
15. Intake manifold
18. Center cowl
21. Vacuum solenoid
22. Vacuum solenoid
23. Rocker cover
- g8dhe
Matt, I've taken the liberty of copying the info to my server here;
http://www.g8dhe.net/bongo%5Fimages/wiki%5Fimages/
If you have any more then its an additional place should we loose the info ever again! Let me know and I'll improve the formatting etc.
