I've not seen anything like this for the Bongo, other than the fantastic set of diagrams we are lucky enough to have at http://lushprojects.com/bongopartsmk2/
I intend to keep this and the other images up to date on the wiki at http://mazdabongo.wikispaces.com/Parts. Corrections, additions and contributions are all welcome. In particular, a set of underbody images to annotate would be very useful.
1. Air filter housing
2. Fuel filter body
3. Power steering fluid reservoir
4. Automatic Transmission Fluid (ATF) dipstick
5. Throttle Position Sensor (TPS)
6. Temperature Sender
7. (Blanked) Exhaust Gas Recirculation (EGR) joint
8. Intake manifold elbow
9. Vacuum advance tube thingy
10. Coolant hose
11. Throttle Idle switch
12. Cold start actuator
13. Throttle cable adjuster
14. Diesel fuel pump
15. Intake manifold
16. Fuel pipes bracket
17. EGR vacuum tube thingy
18. Center cowl
19. Fuel injector (1 of 4)
20. EGR vacuum solenoid
21. Vacuum solenoid
22. Vacuum solenoid
23. Rocker cover
24. Glowplugs bar thingy
TODO list (just on this image)
- fix any errors
- add more parts
- part numbers and links to lushprojects.com
- publish hi-res version
- break-out a close-up of the pump/throttle area
Peace,
Matt.
