Stick On LED Strip Lights
Moderator: Ian
Just got a set of those flexible LED driving lights and wandered what is the best double sided tape to use to stick them on the Bongo, dont want them falling off
Tony
Tony
Re: Stick On LED Strip Lights
I've used the Halfords number plate tape for a few things,seems pretty good.
- daveblueozzie
Its called body moulding tape, and most car accessory shops sell it in a roll.
Lost without my Bongo.
M 80NGO
Be sure to thoroughly de-grease the area with some thinners / white spirit and dry with a clean cloth / tissue before fitting as this will ensure a good bond between the lights and the bodywork
then when its all done get some before n after pics up so we can all revel in your self induced LED heaven
cheers guys, still undecided where to fit them but will get pics up once done
If you need any ideas, just check out daveblueozzie's ride, led's everywhere its great. I was going to take the kids to Blackpool but i might just ask Dave to drive past my house with his side door open.
stuc wrote:If you need any ideas, just check out daveblueozzie's ride, led's everywhere its great. I was going to take the kids to Blackpool but i might just ask Dave to drive past my house with his side door open.
lpgimports
make sure you use 3m moulding tape and make sure its degreased first.
Cheap moulding tapes eveything drops off,
I've been playing with these strip leds this week and have some that you can just cut to length, very cool,
Paul
Paul
http://WWW.NEWACRECARS.COM IMPORTERS
- Badger inkslinger
- Bongonaut
bigdaddycain wrote:stuc wrote:If you need any ideas, just check out daveblueozzie's ride, led's everywhere its great. I was going to take the kids to Blackpool but i might just ask Dave to drive past my house with his side door open.![]()
David Edwards
have seen a few vehicle with these now, where do u get em then and I take it they are wired into the side lights.
Got mine form Ebay for around £1.99 but I have also seen them sold on Amazon as well.
Still not fitted mine but I will be simply connecting them to the sidelights
David Edwards
mine arrived this morning, two strips of red and two of white, cheap too, just gotta get some sticky stuff now and wire em in, what is the best to use, number plate tape or is there something else.
- mister munkey
Wire them into the sidelight circuit, I supergued mine on as the 3M tape gave up pretty quick . . .
David Edwards
well I wondered about superglue but thought if they should fail they would be a bugga to remove, will try the tape first I think.
Bought my 'daylight lights' from Halfords, peeled back the adhesive protection paper , cleaned the fitting area bodywork with alcohol, pressed them on, wired up to sidelights... job done 40mins.. they been on the vehicle now some 4 months no sign of peeling off... (your lights should have self adhesive backing you should not need any further adhesive tape)tonnee wrote:Hi
Tony
