Got new exhaust system,glow plugs,air/oil filter,oil all done.
Disc n pads next week and the bongo be good for plenty more miles.
The drivers window switch packed up this afternoon,:( so if anyone got
a working one going for sale drop us a pm.
Cheers Paul
Parts fitted
M 80NGO
Re: Parts fitted
bawgixer wrote:Got new exhaust system,glow plugs,air/oil filter,oil all done.
Cheers Paul
Great work there paul you can't beat a pre winter splurge, Whats wrong with the switch ( you haven't pressed the lock button for the passenger window have ya )
- missfixit70
Re: Parts fitted
Have you checked it's not the wiring loom between the drivers door & the body that's the problem with the window switch- usually is.
Re: Parts fitted
Lots of clicking noises from the switch when pressed up or down
M 80NGO
Re: Parts fitted
could it be a relay or even motor then ?bawgixer wrote:Lots of clicking noises from the switch when pressed up or down
Re: Parts fitted
The noise comes from inside the switch box .have removed it from the door card and if u hold it to your ear you can hear the clicks
Re: Parts fitted
Bit later than planned,but that the new disc and pads all round on today.
Front drop links also done if that sounds right
Re: Parts fitted
Had exactly the same problem on mine the other week, intermittent electric window operation then a chattering noise when the switch was pressed and now wont work at all, not looked into it yet, but I suspect the wiring as missfixit mentions, mine looks like it has been repaired before (badly) so will be taking a look at it in the next week or so.
