cold starting problems
bongowyart
Post by bongowyart » Wed Sep 21, 2011 3:48 pm
Hi all. I am having big problems starting my p plate bongo 2.5d from cold. it Will not start unless i spray a starter spray into the airbox and its still a struggle. Once up and running it blows a lot of white smoke, but then its fine and runs perfect. Also it will then start once warm no probs. I have had the glow plugs replaced at a local garage, along with a service but this has had no effect and they have no clue what else it could be?? They also checked a relay controlling the plus was working and they think it is.
Any thoughts are greatly appreciated!!
:? peter
BongoMTBer
Re: cold starting problems
Post by BongoMTBer » Wed Sep 21, 2011 3:54 pm
Check the volts are getting to the glow plugs. It could be your relay.
Post by g8dhe » Wed Sep 21, 2011 3:58 pm
bongowyart wrote:They also checked a relay controlling the plus was working and they think it is.
Think ?? The only have to put a meter on the Glowplug bus and they will see if its working and that volts are getting to the plugs themselves and that the voltage is the full 12+ volts, there shouldn't be any thinking involved! If they only listened for a clicking noise that's not actually checking it at all :-(
Post by missfixit70 » Wed Sep 21, 2011 3:58 pm
Did they check the voltage was getting to the glow plug rail?, have they checked the fusible link connected to the starter battery positive terminal? Did they fit decent - ie NGK glow plugs?, a lot of the cheaper ones are crap TBH. Did they fit shorter glow plugs & now the glow plug rail is touching the fuel rail, shorting it out?
Did they check for fuel leaks around the fuel pump & hoses/pipes to see if air was being drawn in?
This thread may help - http://www.igmaynard.co.uk/bongo/forum/ ... sible+link
Welcome to the forum BTW :D
Post by missfixit70 » Wed Sep 21, 2011 4:00 pm
Stick your location in your profile by clicking on "user control panel" top right, there may be some local help forthcoming.
The Great Pretender
Post by The Great Pretender » Thu Sep 22, 2011 2:33 am
missfixit70 wrote: Did they check for fuel leaks around the fuel pump & hoses/pipes to see if air was being drawn in?
Good call, you can't ignite fresh air no matter how good the glow plugs are................. :wink:
To infinity and beyond
