ADAMD
Post
by ADAMD » Mon Sep 19, 2011 2:38 pm
Hi, I am replacing the outer front CV boot, following the fact sheet.
I have got to the bit that says 'remove disc'
Disc does not want to be removed, please can anyone help with the method.
Many thanks
Adam
This is where I am at:
Post
by Northern Bongolow » Mon Sep 19, 2011 2:58 pm
as far as im aware it should just slide off,it may be stuck so give it a clout from the back.
wonkanoby
Post
by wonkanoby » Mon Sep 19, 2011 4:26 pm
yeah wack it
briwy
Post
by briwy » Mon Sep 19, 2011 5:17 pm
Put the nut back on loosely, and tap it (with a piece of wood between)
Used to do it with Minis, worked a treat. Not tried on a Bongo, yet, but it should work OK.
ADAMD
Post
by ADAMD » Mon Sep 19, 2011 6:11 pm
Thanks guys, I needed a bit of confidence to hit it a bit harder.
Used larger hammer and came off no problem.
Thanks Again.
ps. I got the outer boot from local factors, anyone know if inner is the same or also available, they only had outer listed.
teenmal
Post
by teenmal » Mon Sep 19, 2011 6:26 pm
ADAMD wrote:Thanks guys, I needed a bit of confidence to hit it a bit harder.
Thanks Again.
Hi,you can check the part numbers for the boots here.. 22-540 inner and 22-530 outer..
http://lushprojects.com/bongopartsmk2/c ... no=.html#4
ADAMD
Post
by ADAMD » Mon Sep 19, 2011 6:56 pm
Thanks,
Outer seems to be available everywhere, Inner not so - Jap spares on ebay seems only place to list inner
mikexgough
Post
by mikexgough » Mon Sep 19, 2011 9:30 pm
don't forget the copper grease on reassembly .......not on the brake disc surface I hasten to add...
ADAMD
Post
by ADAMD » Tue Sep 20, 2011 2:11 pm
Thanks, Inner and outer ordered from Auto Jap spares.
Now just my split rubber on the ball joint to worry about - any advise??
Adam
teenmal
Post
by teenmal » Tue Sep 20, 2011 2:26 pm
ADAMD wrote:Thanks, Inner and outer ordered from Auto Jap spares.
Adam
Hi Adam,
you should be able to obtain a ball joint boot from your local motor factor,giving them the pysical dimentions will help..
ADAMD
Post
by ADAMD » Tue Sep 20, 2011 5:21 pm
Thanks Teenmal, I didnt think the ball joint boot was replacable, Is it easily done?
That would save a major headache, although I do need the next size up joint splitter!!
Adam
teenmal
Post
by teenmal » Tue Sep 20, 2011 5:28 pm
ADAMD wrote:Thanks Teenmal, I didnt think the ball joint boot was replacable, Is it easily done?
Adam
Hi Adam,this will give you an idea,scroll down the page.You dont need a splitter,just give the carrier a sharp blow on the rounded edge,remove the nut first.
http://www.ebay.co.uk/itm/180718627915? ... 1423.l2649
Cheers..
ADAMD
Post
by ADAMD » Tue Sep 20, 2011 6:32 pm
That looks a great solution thanks.
Which bit do you mean by the carrier?
teenmal
Post
by teenmal » Tue Sep 20, 2011 7:20 pm
ADAMD wrote:That looks a great solution thanks.
This bit, 33-020 they call it a knuckle.
http://lushprojects.com/bongopartsmk2/c ... no=.html#2
If you look at the bit that the ball joint fits into,give the rounded side facing the centre of the van a sharp smack right on the centre of the carrier(round bit),the ball joint should jump out.If you are not too sure use a splitter.
Cheers.
