Not the right answer! However, the heat shield disintegrated when removed, and I need to find a new one quick before Marianne's big end gets any hotter...........bongoing-mad-simon wrote:hi ian , no manifold heat shield???? not that i know anything about engines LOL just mines got one and this one hasn't .....
Yes, well done Dave, you win.dave_aber wrote:That manifold is different to mine - the take-off at the back, which looks like a blanked EGR take-off is a flanged joint. On mine (1997) the EGR outlet is a big pipe with a threaded fitting, like a big plumbing fitting.
Is it a Bongo manifold?
I think I have all the bits you need. Will drop you an email.Ian wrote: So i'm trying to track down a (flat) manifold which has the EGR pipe, and then get a new inlet hose fitted, all by the time I drive down to Looe.
