DIY non invasive temperature gauge probe placement ideas...
Re: DIY non invasive temperature gauge probe placement ideas
I had one of there before i saw this post ,i was messing about with temp reading on the fuel side not coolant(i know..i know),i found that my reading would only stay on oc after shining a light on it(thats how you change it from oc to f) do you guys have the same ??
It would sat in oc if i didnt disconnect the power to the unit,would this be ok to leave on all the time on a lesuire battery?? i fitted a cig lighter socket to the end.
- missfixit70
I'd put it onto the SB on an ignition switched circuit TBH Jez, why do you need it on the LB? You only need to see the temps with the engine running don't you?
My thermometer switches from celcius to farenheit by flashing a light/torch at the display,when power is lost it goes bak to farenhiet,iam not good with farenhiet!!..
- missfixit70
Yeah, but it doesn't need to be on all the time - ie when your stopped, hence my post above - nowt to do with which temp scale
EDIT, got what you're getting at now
Can't help with that one, sounds like it may be an american origin unit if it's default is fahrenheit?
Its from company above,i got the 2 probe model but one didnt work.
Its a sure me-sp331 in blue...was using it to record heat on flow and return of the injection pump.
may get another ,if i can find one that works!
- rhino-wayne
Fitted my gauge next to the BMW clock,
twas a bit of a struggle
to feed the cable down to the top hose but got there in the end
Next day set off on a 1000km trip of Wales
, the gauge provided so much more info/entertainment
than the Mazda (wake up at 11o'clock gauge
) ....had to remind myself to watch the ROAD
as well as the gauge
They can be set like that... There is a four way type dip switch on the back behind the cover on the PCB...chipvan wrote:I had one of there before i saw this post ,i was messing about with temp reading on the fuel side not coolant(i know..i know),i found that my reading would only stay on oc after shining a light on it(thats how you change it from oc to f) do you guys have the same ??
A bit like this?
I set mine to read both channels in Celsius..
There is a light sensor in the top left of the screen.. The more light hits it the brighter the readout, when dark it dims so as not to dazzle...
I actually moved my gauge to the top din slot, above the radio, so it can react more in bright light... Nice clear read!
See my post above... You may need to set the dip switch to get the second probe to work??chipvan wrote:Its from company above,i got the 2 probe model but one didnt work.
you what!!!!! ive been such a numpty!!!!!...just tried it and bingo !!!
will wire that in 2mrw..
Thank you so so much!!!
http://www.sure-electronics.net/downloa ... 1.0_EN.pdf
I found it quite intuitive... A bit like setting up the old SMPTE analogue MIDI track striper i used to have...! (Still have...)
OK,chipvan wrote:you what!!!!! ive been such a numpty!!!!!...just tried it and bingo !!!
Thank you so so much!!!![]()
Then i will put some kind of "fact sheet" together.... Cuz in fairness, it can take some sussing out....
Just let me finish off replacing my fuel hoses first!? I spent an hour in the dimming light looking for my wedding ring last night, after it dropped into a Bongo cavity after my hand got caught..
PHEW thats lucky!!!! you would have been in some serios trouble if you lost it!...well at least it was in a good cause!!
got mine fitted,ive got it on the top hose itself,just fixed on with a cable tie.
the display is where the spare swithces are on dash to left of steering wheel.
You maybe interested in reading this...?!!chipvan wrote:got mine fitted,ive got it on the top hose itself,just fixed on with a cable tie.
The display placement is as good a place as any...
I'd put mine there, but I've got front fog & spot switches there. I've got a voltmeter in the other side, and 2xblind switches below.
I'll find somewhere!
