need to top up the oil will 10w-40 be OK?
Travis
I need to top up the oil, not sure what was used at service, will 10w-40 be OK? or should I buy some 10w-30?
Many thanks
Travis
Many thanks
Travis
- westonwarrior
Re: need to top up the oil will 10w-40 be OK?
If you know who serviced it give them a ring if not I have not heard anything to say you can't mix on top ups.
I have in the past.
I have in the past.
- haydn callow
Yes ! dosn't really matter 10/40 will be fine.....
- haydn callow
- haydn callow
why does it do that somtimes ??? defo didn't press the buttons twice ?
- baronweetman
I bet if it was paying out fivers instead of posting comments it wouldn't show up twice
[b]la connaissance exacte du passé, en éclairant le présent, vous permettra d'agir sur l'avenir[/b]
10/40 Is the most common oil used generally, so the chances are the bongo has 10/40 in it anyway. Westonwarriors suggestion on contacting the dealer/mechanic is a good idea if you are a little apprehensive about putting "any old oil" in....
It's refreshing to see this being asked about
It's a different story with the coolant though! Don't mix that stuff!
Not on a bongo!
better to find out if its mineral/semi synthetic/or full syth first though, all available in all grades.
10w-40 is fine as others have said. 5w-30 is the recommended viscosity according to some sources but since you are only adding 0.5-1 litre to 6 litres (15%) it is quite academic really. Better to have enough oil than worry about what oil although personally I prefer fully synthetic. Just make sure your top up oil is of good quality.Travis wrote:Hi
Many thanks
Travis
On the other hand why do you need a top up? Should you be looking for a leak?
Live Bongo and prosper.
Travis
No top up needed now for a year between services, just being cautious as planning a trip away
Cheers everyone
Cheers everyone
