need to top up the oil will 10w-40 be OK?
Travis
Post by Travis » Thu Jun 09, 2011 7:17 am
I need to top up the oil, not sure what was used at service, will 10w-40 be OK? or should I buy some 10w-30?
Many thanks
Travis
westonwarrior
Re: need to top up the oil will 10w-40 be OK?
Post by westonwarrior » Thu Jun 09, 2011 7:33 am
If you know who serviced it give them a ring if not I have not heard anything to say you can't mix on top ups.
I have in the past.
haydn callow
Post by haydn callow » Thu Jun 09, 2011 8:32 am
Yes ! dosn't really matter 10/40 will be fine.....
http://www.coolantalarm.co.uk
Also BMW Clocks
haydn callow
Also BMW Clocks
haydn callow
Post by haydn callow » Thu Jun 09, 2011 8:34 am
why does it do that somtimes ??? defo didn't press the buttons twice ? :? :?
Also BMW Clocks
baronweetman
Post by baronweetman » Thu Jun 09, 2011 9:45 am
I bet if it was paying out fivers instead of posting comments it wouldn't show up twice :lol:
[b]la connaissance exacte du passé, en éclairant le présent, vous permettra d'agir sur l'avenir[/b]
Post by bigdaddycain » Thu Jun 09, 2011 11:25 am
10/40 Is the most common oil used generally, so the chances are the bongo has 10/40 in it anyway. Westonwarriors suggestion on contacting the dealer/mechanic is a good idea if you are a little apprehensive about putting "any old oil" in.... :wink: It's refreshing to see this being asked about :D It's a different story with the coolant though! Don't mix that stuff! :shock: [-X [-X Not on a bongo! :?
Post by Northern Bongolow » Thu Jun 09, 2011 1:42 pm
better to find out if its mineral/semi synthetic/or full syth first though, all available in all grades.
Jaws
Post by Jaws » Sat Jun 11, 2011 12:34 am
Travis wrote:Hi
Many thanks
Travis
10w-40 is fine as others have said. 5w-30 is the recommended viscosity according to some sources but since you are only adding 0.5-1 litre to 6 litres (15%) it is quite academic really. Better to have enough oil than worry about what oil although personally I prefer fully synthetic. Just make sure your top up oil is of good quality.
On the other hand why do you need a top up? Should you be looking for a leak?
Live Bongo and prosper.
Travis
Post by Travis » Sat Jun 11, 2011 10:18 am
No top up needed now for a year between services, just being cautious as planning a trip away
Cheers everyone
