No Power to Fans
PisceanJoy
No Power to Fans
Post by PisceanJoy » Wed Jun 01, 2011 1:31 pm
One of my alarms went off as I was starting off to go to a festival
Luckily I was near the garage
They have checked and the fans aren't working
Its not the fuses and they say they don't think its the wiring
They don't think they have come across this before
has anyone got any ideas as to what it could be?
Unfortunately unless its something simple (which it doesn't seem to be) they can't delve deeper till friday which means I'll miss the Festival
So any help will be appreciated
321Away
Re: No Power to Fans
Post by 321Away » Wed Jun 01, 2011 1:34 pm
dont they go throught the relays located in front/below the main battery? do the fans work if the apply power directly?
Julian
PisceanJoy
Post by PisceanJoy » Wed Jun 01, 2011 1:54 pm
They haven't checked that yet
Post by g8dhe » Wed Jun 01, 2011 2:28 pm
A quick check you could make is to turn the Air Conditioning on (if you have it) that forces the Fans on, that will prove that the Fans and the relays are OK or not, if they do come on then it would suggest that perhaps the fault is back towards the ECU and temperature sensors (most likely) if they don't come on then it would point towards the Fans, relays and fuses the fuses are;
Image Image Image
the relays are B6-01, B6-02 & B6-03 see top lefthand side;
PisceanJoy
Post by PisceanJoy » Wed Jun 01, 2011 2:41 pm
Yes they tired the aircon on and fans didnt come on
Unfortunately they didnt have time to delve to deep today
Post by g8dhe » Wed Jun 01, 2011 2:52 pm
In that case provided all three fuses are OK, try swapping B6-02 relay with the B6-01 relay, that may allow the Fans to come on at the lowest speed setting, if that happens you may find that they still don't work when a higher speed is requested however it would give you some cooling, not sure that I would want to drive to far however without knowing that the faster fan speeds are available when needed, especially when you stop after a run.
PisceanJoy
Post by PisceanJoy » Wed Jun 01, 2011 6:44 pm
Thanks Geoff I have already abandoned hopes of getting to Festi to work as its in Somerset
Post by g8dhe » Wed Jun 01, 2011 9:44 pm
Ah OK, the relays are easy to get at and very simple to swap however, just behind the offside headlight, 2 black oblong plastic boxes, you want the one closest to the headlight, reach down on the righthand side and there is a simple plastic catch that needs to be pulled out a little, top of the box will then lift away. Inside three black cubes, swap the centre and right hand one, just pull straight up to remove and push back down to insert. The get back inside turn on Ignition and turn on the Air Con, with luck the fans will be turning when you look again.
PisceanJoy
Post by PisceanJoy » Sat Jun 04, 2011 4:15 pm
Sorted It was the sensor at the bottom of the engine Complicated by the fact the aircon's not working but that doesnt bother me too much as I dont use it
Thanks for help from Geoff, Julian and Kirsty :D
Post by g8dhe » Sat Jun 04, 2011 5:12 pm
Glad they sorted it, always a pain when two faults exist :-(
Post by missfixit70 » Sat Jun 04, 2011 6:09 pm
Nice one Joy, glad they got there, looks like they've learnt a bit more about the bongo & its cooling system too :wink: Does that mean the AC gas needs topping up too, if switching that on didn't activate the fans?
Always better to actually disconnect the engine temp or ac switch to see if the fans are working.
PisceanJoy
Post by PisceanJoy » Sat Jun 04, 2011 8:21 pm
Yes They will re - gas ACon when they do a service at end of month
Post by missfixit70 » Sat Jun 04, 2011 8:24 pm
Needs using regularly to maintain the seals, at least once a month even during the winter. If you don't already, use it to help demist the windows, much quicker :wink:
