Anyways
The roof will not go up, i've tried all the std things to check
Black box in R Arch
H/brake switch
Cancel switch in roof
Fusebox etc
but i still cant it to budge.... I know it worked last time it was used about 9 months ago
There is one extra factor to this equation though there is a piece of memory foam in the roof, that must have been put in through the front of the awning as i had to hack away at the hatch to gain access to the cancel button.
What happens
P & engine running, hand brake on
press switch on roof,warning light on dash flashes yet dimmer as do the other warning lights??
warning buzzer sounds but no movement or noise from motors?
Please can anyone help thanks
