Roof Beeping
dandemann8
Roof Beeping
Apoligie's if already asked but I can't find my answer so here go's, on opening my AFT the "beep's" continue after AFT is fully open
so if anyone as any idea's I would be most welcome
Bongo no more........... ;-(
- daveblueozzie
Re: Roof Beeping
Some times it needs a little help to get fully up
give it a push for the last second or two to help it get in the fully open position, this should stop the beeps.
Lost without my Bongo.
dandemann8
Re: Roof Beeping
Cheer's Dave will give it a little help next time after all were all getting old
AlliDelta
Re: Roof Beeping
Are you raising the roof with the engine running? If the engine isn't running sometimes mine doesn't get fully erect.
We Need Moore Pooower!
- mikexgough
Re: Roof Beeping
Duncan....when is the last time you put it up..... ROOF....that is..... might need a few raise and lowers and some lube on the runners...
dandemann8
Re: Roof Beeping
mikexgough wrote:Duncan....when is the last time you put it up..... ROOF....that is..... might need a few raise and lowers and some lube on the runners...
To be honest Mike this is only the second time I got it up in a month
Roof alway's raised with engine running but let gravity to the rest to get it down
skyhigh123
- Bongonaut
Re: Roof Beeping
If you are going to push the roof up, make sure that you push on the aluminium edges which have the screw in connectors rather than the roof itself. If you push too hard on the roof there is a danger of popping out the screws which hold the roof to the aluminium edges.
- gmaczbongo
Re: Roof Beeping
Hold the up button when you give it a wee help
- PixieAndTheMoon
Re: Roof Beeping
Ok potentially a problem for AFT Bongo's......LOL
Jo
Jo
Mattylad
Re: Roof Beeping
I have posted something about my roof, but also says about getting rid of the not being able to get it fully up, ya know being a bit flacid, take a peek.
Matty
Matty
