Rear wheel won't turn in reverse
andynew74
Has anyone got any ideas??
I took my Bongo for an MOT and they informed me the N/S rear wheel brake was binding, so i checked it out and removed the brakes including the disc, so the hand brake shoes were exposed. The wheel turns forward fine but only turns by force in reverse.. There is no diff noise and in forward its fine but you can tell there is resistance when reversing..
I had replaced a wheel stud a few weeks ago so at first suspected it was a mistake when i put the hand brake shoes back together, but as previously explaned after removing thye brakes the problem is still there???
Has anyone any ideas?? All i can think is the diff is the problem? Has anyone had the same problem?
- You've Been Bongod
Re: Rear wheel won't turn in reverse
put your location in your profile to help people near to you to help you
HeskinBongo
Is there any end float in the hub unit ? so that in reverse the float causes an issue within the diff ?
andynew74
Not sure about the end float. I'm going to whip the disc off again and have a good look.
Can the end float be adjusted??
Hi andynew74,
Does your vehicle have a LSD.....Limited Slip Differential?.
Cheers.
Cheers.
andynew74
I think so.
steviebongo
- Tribal Elder
Just a stab in the dark but how's the handbrake shoes , the lineing could have fell off ?
andynew74
I've just had a look. There appears to be no issue with brakes inc. handbrake shoes. I disconected the propshaft to eliminate anything else. It seems just one wheel won't go back without a lot of force. I am guessing its definatly the diff?? Not sure if LSD or not can't see ant tags on it. Does anyone know any good axle people??
andynew74
I have checked on that russian site and i do have a LSD, and its 4WD.
M 80NGO
have you tried it with either both rears or all four wheels off the ground ? Is the auto box in nuteral ?
M 80NGO wrote:have you tried it with either both rears or all four wheels off the ground ? Is the auto box in nuteral ?
Quote....I disconected the propshaft to eliminate anything else
M 80NGO
teenmal wrote:M 80NGO wrote:have you tried it with either both rears or all four wheels off the ground ? Is the auto box in nuteral ?
Sorry buddy it was along day that day
