Gear lever locks
Bongopoet
Gear lever locks
Post by Bongopoet » Wed Mar 30, 2011 8:45 pm
We are thinking of getting a gear lever lock. We were wondering if any one in Bongoland uses one and if so have they found them effective? Also if so what size should we be buying?
Chrissy
dobby
Re: Gear lever locks
Post by dobby » Wed Mar 30, 2011 9:38 pm
I'm sure we use an Autolock on ours - a bright yellow one, oour bongo is in the menders at the moment :roll: so I can't check
Just googled this:
http://i285.photobucket.com/albums/ll44 ... CF0717.jpg
This isn't my photo and it's not a bongo. :lol:
Halfords will be able to advise - let you try one?
You've Been Bongod
Post by You've Been Bongod » Wed Mar 30, 2011 9:41 pm
i use a full disclock for the steering wheel
Diplomat
Post by Diplomat » Wed Mar 30, 2011 9:47 pm
Very heavy motorcycle type cable and padlock wound several times round gear and around brake pedal.
Can't move stick or depress brake.
I use a massive padlock for all to see.
Frank
They flew, I took up naturism
Bongopoet
Post by Bongopoet » Wed Mar 30, 2011 9:50 pm
Diplomat wrote:Very heavy motorcycle type cable and padlock wound several times round gear and around brake pedal.
Frank
Thanks Frank we have one of those cables and a padlock so shall try that.
Chrissy
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Post by M 80NGO » Wed Mar 30, 2011 10:03 pm
dobby wrote:I'm sure we use an Autolock on ours - a bright yellow one, oour bongo is in the menders at the moment :roll: so I can't check
Just googled this:
OMG that has to be the most worthless peice of anti theft i have ever seen, how long would it take to unscrew that gear knob and get that peice of tat off, even with an auto "T" Handle those rivets look like they'd melt like butter if you went near them with even a half decent cordless drill,
I say the above as when i was roadsiding for the AA this is exactly how we used to remove these when owners had lost the keys usually 10 seconds to remove.
If money's tight then For about £90 you can get a cat2 immobilizer supplied n fitted :wink:
dobby
Post by dobby » Wed Mar 30, 2011 10:05 pm
:lol: :lol:
Good point
we keep an attack ferret in the back as well though.....
M 80NGO
Post by M 80NGO » Thu Mar 31, 2011 5:18 pm
dobby wrote::lol: :lol:
Good point
I'd defo have more faith in the ferret than that other peice of tin :wink:
Bongopoet
Post by Bongopoet » Thu Mar 31, 2011 7:25 pm
Hmm The ferret attack ferret is tempting! =D> =D>
