Aircon fan
al & chris
- Tribal Elder
Aircon fan
With aircon on i am sure i used to hear the fan come on behind radiator. Cant seem to make it come on now. Is this because of outside temp in winter or has is stopped working. Seem to remember it coming on quite a lot.
MAZABON
Re: Aircon fan
hi
it does have a protection system to stop it working in low temp, but i am not sure what it is set at, somewhere near to freezing i would have thought ?
al & chris
- Tribal Elder
Re: Aircon fan
mmm! quite a bit above freezing now . Are others coming on in this weather we have now.
MAZABON
Re: Aircon fan
hang on ill go and find out
MAZABON
Re: Aircon fan
ok, just fired mine up and the fans kicked in as soon as i switched it on, its about 8*C here at the mo
hope this helps
hope this helps
al & chris
- Tribal Elder
Re: Aircon fan
Thanks mine must have stopped working.
Re: Aircon fan
It's normal with the aircon on
Re: Aircon fan
Hi al & chris,
Your system might be needing charged,the fan wont come on if you have lost pressure in the system.
Cheers..
Cheers..
Re: Aircon fan
My fans start with aircon when temp is around freezing point so yours has probably lost pressure and need re-gassing .
Re: Aircon fan
or the white plugged starter solenoid has stopped working.
if its a diesel.whats the start up revs like,are they lower than the second mark up on the rev counter when started from cold
Re: Aircon fan
Hey up Ady, here we go again!!!Northern Bongolow wrote:or the white plugged starter solenoid has stopped working.
Re: Aircon fan
its needed isnt it jamie for the aircon to kick up?????.
just checking seeing as your the x pert.
Re: Aircon fan
Yes indeed!Northern Bongolow wrote:its needed isnt it jamie for the aircon to kick up?????.
al & chris
- Tribal Elder
Re: Aircon fan
Ok its not working is re gas fist check?
Re: Aircon fan
I would be looking at it this way... When was the AC system last get re-gassed?
