Aircon fan
al & chris
Aircon fan
Post by al & chris » Sun Feb 13, 2011 12:38 pm
With aircon on i am sure i used to hear the fan come on behind radiator. Cant seem to make it come on now. Is this because of outside temp in winter or has is stopped working. Seem to remember it coming on quite a lot.
MAZABON
Re: Aircon fan
Post by MAZABON » Sun Feb 13, 2011 12:59 pm
hi
it does have a protection system to stop it working in low temp, but i am not sure what it is set at, somewhere near to freezing i would have thought ?
al & chris
Re: Aircon fan
Post by al & chris » Sun Feb 13, 2011 1:07 pm
mmm! quite a bit above freezing now . Are others coming on in this weather we have now.
MAZABON
Re: Aircon fan
Post by MAZABON » Sun Feb 13, 2011 1:20 pm
hang on ill go and find out
MAZABON
Re: Aircon fan
Post by MAZABON » Sun Feb 13, 2011 1:28 pm
ok, just fired mine up and the fans kicked in as soon as i switched it on, its about 8*C here at the mo
hope this helps
al & chris
Re: Aircon fan
Post by al & chris » Sun Feb 13, 2011 1:41 pm
Thanks mine must have stopped working.
Re: Aircon fan
Post by francophile1947 » Sun Feb 13, 2011 2:29 pm
It's normal with the aircon on 8)
teenmal
Re: Aircon fan
Post by teenmal » Sun Feb 13, 2011 3:04 pm
Hi al & chris,
Your system might be needing charged,the fan wont come on if you have lost pressure in the system.
Cheers..
splitpin
Re: Aircon fan
Post by splitpin » Sun Feb 13, 2011 4:22 pm
My fans start with aircon when temp is around freezing point so yours has probably lost pressure and need re-gassing .
Re: Aircon fan
Post by Northern Bongolow » Sun Feb 13, 2011 4:27 pm
or the white plugged starter solenoid has stopped working.
if its a diesel.whats the start up revs like,are they lower than the second mark up on the rev counter when started from cold
jaylee
Re: Aircon fan
Post by jaylee » Sun Feb 13, 2011 4:37 pm
Northern Bongolow wrote:or the white plugged starter solenoid has stopped working.
Hey up Ady, here we go again!!! :P :wink:
Re: Aircon fan
Post by Northern Bongolow » Sun Feb 13, 2011 4:41 pm
its needed isnt it jamie for the aircon to kick up?????.
just checking seeing as your the x pert. :lol:
jaylee
Re: Aircon fan
Post by jaylee » Sun Feb 13, 2011 6:34 pm
Northern Bongolow wrote:its needed isnt it jamie for the aircon to kick up?????.
Yes indeed! :mrgreen: But then even before i replaced my vacuum solenoid the fan came on with the AC... Just the idle speed dropped... 8-[
al & chris
Re: Aircon fan
Post by al & chris » Sun Feb 13, 2011 8:21 pm
Ok its not working is re gas fist check?
jaylee
Re: Aircon fan
Post by jaylee » Sun Feb 13, 2011 8:33 pm
I would be looking at it this way... When was the AC system last get re-gassed?
