My Willinton Split Charger
- Bully bongo
Hi everyone.A querry with my split charger.Everything appears to be working ok,but last nite i was under the bonnet and i saw a small LED light next to the fuses was on, on my split charger.It has been fitted for round about 6 months and i have never noticed this before.When i checked this morning it was off.Does anyone know if this is normal or is it indicating a problem.Many thanks again
- dandywarhol
Re: My Willinton Split Charger
The small green led on the relay box indicates the charging circuit is in operation - engine running.
My wee light was on constantly with the ignition off and I ended up sending it back to Willington as the relay was buggered - To form, he fitted a new one without quibble and all was well once again
Drop Willington a line and that should solve your prob.
J.
J.
I'll tell you this...
No eternal reward will forgive us now
For wasting the dawn.
- Bully bongo
Hi there the light is on when engine is running and stops on for a bit when ignition is off.E-mailed willinton to see what the crack is.Voltage and that is fine.Just tried the engine on and off and the light went straight out.
. I wonder if it could be holding a bit charge
.I charged my battery at the beginning of the week and it seems to have started to do this then.Thanks for the replies.
- hembramacho
Could be wrong, but I was always under the impression that when the starter battery reaches a certain voltage, due to the engine starting/alternator, the Willinton relay clicks on (green light comes on) and the leisure battery starts charging. When the engine is switched off, it takes a bit of time for the starter battery to come down to below the voltage of what it need to be to charge the LB, hence why the green light stays on for a while after ignition is switched off.
Andrew
Andrew
- Bully bongo
Well hembramacho you are exactly right
got e-mail from willinton more or less said there was nothing to worry about and to me what you are saying sounds spot on.I not worry now.Thanks to all again.Another one down to experience
.Happy again going away last week in Feb so it will get a dam good try out.WEE LED as we say up here
- hembramacho
Bully bongo wrote:Well hembramacho you are exactly right![]()
I'm sure it won't go to my head!
Andrew
