Stills smells like an overheated engine ?
Some months ago our bongo had some overheating issues, Cylinder head / Gasket all OK, replaced Rad, several pipes, stat. Over time I've replaced most silicone pipes with new blue /red ones.. so a lot of new stuff BUT, still, when the Bongo warms up, and I've got the heating on, it smells like an overheated car.. you know the smell, slighly fishy !
Question is, can I ever get rid of that smell from the engine ? replacing the heating matrix ? Any other tips ?
Cheers.
Cheers.
Hi im Simon
Re: Stills smells like an overheated engine ?
you may have a leaking front heater or pipework to it.
do a pressure test. does it use any coolant.?
Have a look around the top edge of the radiator. If it is weeping the antifreeze fries on the hot metal.
Frank
Frank
They flew, I took up naturism
Hi mayk19,
You could try running with your heater control on RECYCLE and see if that makes a difference,if so you will know where to look.
Cheers..
Cheers..
thanks for tips..
Doesnt use any coolant. good idea on the Recycle.
When your outside the Bongo, when you've parked up after a run, I can smell it too.
Hi im Simon
- dandywarhol
Check for a mackerel stuck up the heater inlet.
it could be a red herring??!dandywarhol wrote:Check for a mackerel stuck up the heater inlet.
jaylee wrote:it could be a red herring??!dandywarhol wrote:Check for a mackerel stuck up the heater inlet.
no PLAICE for that kind of joke!!
- dandywarhol
No trout about it!!soulpaul wrote:jaylee wrote:it could be a red herring??!dandywarhol wrote:Check for a mackerel stuck up the heater inlet.
- dandywarhol
Sorry to keep carping on but any decent replies yet?
seem to recall some one saying about all the grot in the cooler rad for the a/c
his may help..? http://www.igmaynard.co.uk/bongo/forum/ ... olive+fork
dandywarhol you're a DAB hand at the fish jokes.
COD not think of any more at the moment.
- dandywarhol
I knew the thread would be saith in your hands - and I can see you're putting your sole into it
