Which wheels drive the bongo
Darrenl
Post by Darrenl » Thu Dec 23, 2010 10:30 pm
Yesterday I was trying to reverse in my driveway, I had on half the van on ice and the other on dry paving, the rear wheel (offside) on the ice span with no traction and the other rear wheel just sat there doing nothing, I would have expected the wheel on the paving to work and help the other out, so my van was stuck and I had to use the other car, which is a 4x4 so it had no problems, my bongo is a 2 wheel driver so is a bongo a rear wheel drive? And secondly is it right that only one wheel should drive in reverse?
Darren
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Re: Which weeks drive the bongo
Post by M 80NGO » Thu Dec 23, 2010 10:35 pm
Darrenl wrote:Yesterday I was trying to reverse in my driveway, I had on half the van on ice and the other on dry paving, the rear wheel (offside) on the ice span with no traction and the other rear wheel just sat there doing nothing, I would have expected the wheel on the paving to work and help the other out, so my van was stuck and I had to use the other car, which is a 4x4 so it had no problems, my bongo is a 2 wheel driver so is a bongo a rear wheel drive? And secondly is it right that only one wheel should drive in reverse?
Darren
Yes buddy without going into it in to much detail your Diff will always put power to the wheel with the least resistance ie the one on the slippy stuff :wink:
scanner
Post by scanner » Thu Dec 23, 2010 10:53 pm
Yes that is how a common or garden differential works - for both wheels to drive you need a limited slip differential which drives both half shafts and thus both wheels through an arrangement of clutches.
haydn callow
Post by haydn callow » Thu Dec 23, 2010 11:07 pm
2 WD = Rear Wheel Drive
http://www.coolantalarm.co.uk
Also BMW Clocks
Diplomat
Post by Diplomat » Thu Dec 23, 2010 11:17 pm
I'm working on a revolutionary solution where the handbrake can be applied to the spinning wheel only.
That should get the good wheel turning!
Frank
They flew, I took up naturism
scanner
Post by scanner » Thu Dec 23, 2010 11:29 pm
Diplomat wrote:I'm working on a revolutionary solution where the handbrake can be applied to the spinning wheel only.
Frank
Revolutionary? only in the sense of wheels going round, that idea has been around for years.
It's now done automatically and called "Traction Control"
Diplomat
Post by Diplomat » Thu Dec 23, 2010 11:51 pm
Frank
My pun didn't go to waste!
Without giving away too much, I intend using a length of Dacron rope out of the appropriate front door terminated in a hook to pull the mechanism at the wheel.
Necessity is the mother of invention!
Frank
Darrenl
Post by Darrenl » Fri Dec 24, 2010 12:26 pm
Cheers all, so the solution is to stick a hook into the tyre and a price of rope to stop the wheel from rotating o:) or get off my fat butt and clear the snow off the drive before it turns to ice
Post by missfixit70 » Fri Dec 24, 2010 4:05 pm
Bit of old carpet under the drive wheels'd probably be enough to give you grip, either that or some rocksalt/grit/sand.
Also get used to using the Auto box to your advantage (assuming that's what you've got) - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=38644 - if you've got a manual, try setting off in a higher gear.
dave_aber
Post by dave_aber » Fri Dec 24, 2010 4:11 pm
I wouldn't hook the wheel or tyre with a rope, if you like the number of fingers you already have. The idea of manually activating one handbrake or the other, whilst a bit heath-robinson, would probably work. An old bit of carpet under each wheel is far more traditional though...
Image...Image
Post by missfixit70 » Fri Dec 24, 2010 4:12 pm
Any chance a kind mod or admin could alter the title of the thread to make more sense? :wink:
Diplomat
Post by Diplomat » Fri Dec 24, 2010 7:54 pm
missfixit70 wrote:Any chance a kind mod or admin could alter the title of the thread to make more sense? :wink:
Diplomat
Post by Diplomat » Fri Dec 24, 2010 7:57 pm
Thanks, Kirsty and the mod.
I was going to suggest "The second and fourth in each month".
Happy Christmas Everyone.
Frank
Re: Which wheels drive the bongo
Post by missfixit70 » Fri Dec 24, 2010 8:09 pm
Not just me biting my tongue then? :wink:
