Bongo Ariel
wyefish
Bongo Ariel
Post by wyefish » Thu Nov 25, 2010 2:43 pm
Somewhere unknown my ariel has snapped off at the base. Does anybody know where I can get a replacement. Could not find any in the Bongo shop!
T9sus4
Re: Bongo Ariel
Post by T9sus4 » Thu Nov 25, 2010 3:13 pm
I thought you were going to put your Bongo in the washing machine. 60 degree spin cycle?
Bongo Shop --> Exterior --> Aerial (last item, £32.50 with member discount)
P***AHO - "Hoptoad" - 1997 2.5TD
2WD - AFT - DIY mid conversion
Re: Bongo Ariel
Post by g8dhe » Thu Nov 25, 2010 3:58 pm
The aerials are at the bottom of the Exterior section http://www.igmaynard.co.uk/bongo/mercha ... m#Exterior
haydn callow
Re: Bongo Ariel
Post by haydn callow » Thu Nov 25, 2010 4:28 pm
when you come to replace your aerial.....mind you don't lose the VERRY SMALL ball bearing.....if you drop it ...it;s gone for good
http://www.coolantalarm.co.uk
Also BMW Clocks
wyefish
Re: Bongo Ariel
Post by wyefish » Thu Nov 25, 2010 4:56 pm
Thanks for the above, chaps. I was agonizing over wether it was an 'e' or an 'a'.
Re: Bongo Ariel
Post by g8dhe » Thu Nov 25, 2010 5:07 pm
Depends; 'e" for washing clothes, or 'a' for listening to the wireless :D
Re: Bongo Ariel
Post by francophile1947 » Thu Nov 25, 2010 5:16 pm
g8dhe wrote:Depends; 'e" for washing clothes, or 'a' for listening to the wireless :D
Don't forget the extra "e"(after the first "a") to pick up radio signals :lol: :lol: Long live Firefox, with it's spill chucker :lol: :lol:
Gigantor
Re: Bongo Ariel
Post by Gigantor » Thu Nov 25, 2010 11:37 pm
If you fancy something a bit different, there was a thread on the pimp my bongo forum about this:
http://www.igmaynard.co.uk/bongo/forum/ ... lit=aerial
Basically, my aerial (think that's how you spell it!) got chewed up by my AFT. At the advice of Barrington and Scott (thanks guys!) I cut off the remainder of the aerial at the base of the chrome bit (where it joins the black plastic). I then drilled (using an m5 bit) into the "core" of the metal. This was dead easy because the aerial is hollow, so it's like a pilot hole has already been made for you. I then got an M6 tap and cut a thread into the hole, again dead easy, even though I'd never used one before. This then allowed me to screw in a Halfords £10 whippy aerial that should be impervious to future eating attempts by the electric roof [-o< Also, it's straightforward to remove should I ever risk going through a car wash
Personally I think the new aerial looks neater than the old one and I'd say it's probably as easy a job as fitting a replacement official part since there's no ball bearing to lose.
Barrington
Re: Bongo Ariel
Post by Barrington » Fri Nov 26, 2010 12:27 pm
As Gigantor says dead easy and looks smarter too 8) also easy screw off :D
Music is my Sanctuary!
Gripped
Re: Bongo Ariel
Post by Gripped » Tue Dec 28, 2010 12:10 pm
If I do the drill-tap-and screw the aerial with a Halfords job, do I need to remove the aerial from the side of the van or leave it in place to drill etc? I assume there is a wire connecting the aerial at the base.
Re: Bongo Ariel
Post by g8dhe » Tue Dec 28, 2010 1:26 pm
I drilled mine in-situ, the connection is via the rotating hub there are no wires inside the rotating section. Saves loosing the sprung ball bearing which gives the locking detents ;-)
Re: Bongo Ariel
Post by bigdaddycain » Sat Jan 01, 2011 3:45 pm
Barrington wrote:As Gigantor says dead easy and looks smarter too 8) also easy screw off :D
That's neat baz... And STILL on my "to do" list! :shock:
Barrington
Re: Bongo Ariel
Post by Barrington » Sat Jan 01, 2011 5:22 pm
Thank you buddy :D :D
DanO
Re: Bongo Ariel
Post by DanO » Sat Aug 13, 2011 10:59 am
Excellent, will give this a go at some point as I discovered my ariel had been broken by the garage but I'd not really noticed before driving off and changing from CD to fm and wondering why it didn't work......... :evil: .......for the tools etc. it'll be cheaper than a new one at £32+ or something
westonwarrior
Re: Bongo Ariel
Post by westonwarrior » Sat Aug 13, 2011 11:12 am
Heres how if you take the stub off the van first
http://www.igmaynard.co.uk/bongo/forum/ ... =bee+sting
